Username Post: brake pedal assist        (Topic#347961)
jonibood
Reg: 10-14-17
10-30-17 10:22 AM - Post#2712711
I have a new problem which might have been my timing issue this whole time.There is a vacuum line from my firewall attached to my brake pedal which must be a power assist or booster i put in a new check valve but dont have clue one on where this vacuum line attaches i attached to the tee where my tranny line is attached and it changes the idle when you depress it until my 100 shop manual comes in the mail i havent a clue.This was a long postponed build because of health situation with my son so memory is vague if someone knows you would save my censored. ty
LMC Truck
Senior Chevytalk Moderator
10-31-17 05:31 AM - Post#2712776
    In response to jonibood
Cruise control! It deactivates cruise control when the pedal is pressed.
jonibood
Reg: 10-14-17
10-31-17 10:47 AM - Post#2712826
Does that hose connect to the intake or?
jonibood
Reg: 10-14-17
11-01-17 09:39 AM - Post#2712939
ok so with this unhooked i take it wont interfere with how the truck runs i can leave it unhooked and unplugged good to go shouldnt interfere with the running timing of the truck?
11-01-17 12:13 PM - Post#2712964
Find the other end. Any open vac leak to the intake will affect timing. Follow the cruise control diaphragm. Along the line there is a T connection. The brake switch line should go there. When you push the pedal, vac is released disengaging the cruise control.
jonibood
Reg: 10-14-17
11-01-17 01:43 PM - Post#2712974
ty
jonibood
Reg: 10-14-17
12-05-17 12:06 AM - Post#2716921
So most of my problems were solved when i finally found out that i had vacuum leak on the intake manifold itself when they pulled the motor.thanks for all the timely responses.
12-05-17 03:56 AM - Post#2716928
Wow. Was the intake warped? Good find. Thanks for following up.
LMC Truck
Execution time: 0.247 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:28 PM
