Username Post: rear axle bearings        (Topic#347925)
lilrobo
Loc: lexington ky
Reg: 06-03-12
10-29-17 05:30 AM - Post#2712529
is there a video on replacing rear axle bearings ? i am replacing mine,i wanted to know about flange and other seals and gaskets
thanks
1958 Chevy Biscayne
235 6 cyl
2 speed P/G tranny
1953 f100
350 chevy
350 turbo
1955 chevy 210
LS motor (soon)
4l60e (soon)
10-29-17 07:38 AM - Post#2712533
    In response to lilrobo
Shop manual: Link to bearing replacement. ....You will need a retainer plate gasket between retainer and backing plate. Link to Gasket.
lilrobo
Loc: lexington ky
Reg: 06-03-12
10-29-17 09:34 AM - Post#2712545
    In response to acardon
thanks don
do the races come out ? they look like they are made into housing .
1958 Chevy Biscayne
235 6 cyl
2 speed P/G tranny
1953 f100
350 chevy
350 turbo
1955 chevy 210
LS motor (soon)
4l60e (soon)
WagonMan
WagonMan
Loc: Las Vegas, NV
Reg: 10-26-04
10-29-17 02:21 PM - Post#2712573
The bearing is a self contained unit with the race included. The only way the race comes out seperately is if the bearing has failed badly.
The outer race has an o-ring between it and the housing.
Charles
57 210 4dr. Wagon(bought '82)
-350/700r4 Mild Custom
56 BA 4dr. ht.(bought '98)
-265/TH350 Mostly Stock
29 Ford Sedan(bought '75)
-4.3L/TH350(in progress)
lilrobo
Loc: lexington ky
Reg: 06-03-12
10-30-17 05:45 PM - Post#2712742
    In response to WagonMan
just remembered , i didnt mark the rear u-joint when i removed it , is that a big deal ?
1958 Chevy Biscayne
235 6 cyl
2 speed P/G tranny
1953 f100
350 chevy
350 turbo
1955 chevy 210
LS motor (soon)
4l60e (soon)
lhossfeld
Reg: 03-11-18
03-11-18 10:26 PM - Post#2727267
I have access to a press, but I don't have the special support plate J-5741 shown in the manual. Are there any alternative recommendations? It seems like the bottom support in the press should be contacting the bearing inner race directly. If it contacts the bearing retainer, it would probably work, but might damage the retainer.
Thank you
Larry
03-12-18 07:04 AM - Post#2727298
    In response to lhossfeld
J-5741 is a bearing splitter. Link to bearing splitter. The splitter can grab the outter race of the old bearing as your not concerned about damageing it.
YOUNG57
Loc: Tennessee
Reg: 12-06-10
03-12-18 09:16 AM - Post#2727317
The old bearing are removed by nicking its retainer collar with a cold chisel to expand it then the bearing and collar are pressed off together. The new bearing is pressed on by its inner race and then a new bearing retainer collar is pressed on behind the bearing to lock it in place
55 & 56 bearings are sealed on both sides and permanently lubricated by their own grease but 57 bearings are only sealed on the outside and open on the inside to be lubricated by the differential’s gear oil.
YOUNG57
Loc: Tennessee
Reg: 12-06-10
03-12-18 07:37 PM - Post#2727389
Not marking the U-joint and which way you put it back is not a problem. Like installing a new U-joint, it doesn’t matter. Drive shafts are balanced without the transmission or third member and U-joints should be neutrally balanced.
YOUNG57
Loc: Tennessee
Reg: 12-06-10
03-12-18 07:57 PM - Post#2727395
    In response to YOUNG57
The type of bearing “separator” shown are commonly used on hydraulic presses to press things on or off shafts and can be place up or down depending on application.
By turning the separator flat side up and adjusting it close to the axle’s diameter the bearing inner race will set on the separator and can be pressed on or off the axle.
03-13-18 06:39 AM - Post#2727441
I can't get my splitter between the bearing and retainer. The shop manual shows the splitter between the flange and retainer. The retainer only contacts the outer race. Link to shop manual.
models916
Loc: Addison, IL
Reg: 05-28-10
03-14-18 05:44 AM - Post#2727552
Damn, welded ring! Be careful with removing that.
Just press against the outer retainer cuz' you're not going to re-use the bearing.
Edited by models916 on 03-14-18 05:46 AM. Reason for edit: No reason given.
TubT
Loc: Morgan, TX
Reg: 03-11-18
03-28-18 04:51 AM - Post#2729191
    In response to models916
That welded collar would make me think that axle had had previous problems.
Edited by TubT on 03-28-18 04:52 AM. Reason for edit: No reason given.
Execution time: 0.269 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:11 PM
