Username Post: PLZ HELP        (Topic#347916)
Reg: 10-28-17
10-28-17 04:16 PM - Post#2712483
Bought my first chevy for my son a silverado 2500 series gas, 5.7 replaced the Battery, Alternator, Starter, 2- 30 amp fuses inside fuse box, and still NO POWER, NONE what so ever, like the truck doesn't register there is a battery. Thinking maybe electric issue, any thoughts?
Loc: Murphy N.C.
Reg: 01-25-14
10-29-17 02:51 AM - Post#2712522
    In response to 1stchevy
Knowing the year would be helpful, Posting this in the truck section would be also.
Edited by junkman104 on 10-29-17 05:05 AM. Reason for edit: No reason given.
Loc: Utica ny
Reg: 04-13-10
10-29-17 08:53 PM - Post#2712645
    In response to junkman104
check the ground wire off the battery.
Then check the grounds
Not sure of the year but likely there are 2 ground ribbons
one from the back of the right head to the right framerail
the other from the cab to the frame, or to the back of the right head. cant remember at the moment.
Likely the one to the cab rotted off.
It is located right below the heatercore pipes on the firewall.
Give a year and you will get better response
Old School GM fan FOREVER
Execution time: 0.195 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:45 AM
