LMC Truck
Username Post: 88 S-I0 4.3 HAS SPARK WON'T START        (Topic#347912)
chevylover
Reg: 05-25-04
10-27-17 11:36 PM - Post#2712428
I PUT LOTS OF DIST. PARTS IMPROVED SPARK. BEFORE DOING ALL THIS I PUT FURL DOWN THE TBI AND IT FIRED. AFTER ALL THESE PARTS THE ENGINE WILL NOT FIRE AND TURNOVER. DO YOU HAVE ANY IDEAS? CK. FUEL PUMP IT'S FINE I CAN HEAR IT RUN. ANY IDEAS WILL BE TRIED. THANKS
LMC Trucks
Senior Chevytalk Moderator
10-28-17 04:36 AM - Post#2712435
    In response to chevylover
If the fuel pump primes and it starts with fuel down the TBI, fuel pressure may not high enough. First, with the key on, check for power at the fuel injectors. Second, ohm check the pickup coil. The pick coil is used by the ECM to fire fuel injectors. The pick up coil should read 500-1500 ohms. If it reads outside that range, it’s bad. The entire distributor has to come out to replace it. I just did an 87 TBI truck. We ended up replacing the entire distributor. You need a special adaptor to test fuel pressure.
Does it have any codes? Email me. I’ll send you a TBI troubleshooting guide.
chevylover
Reg: 05-25-04
10-28-17 07:23 AM - Post#2712452
HI, THE TRUCK RAN FOR A FEW MOMENTS BEFORE I CHANGED ALL THOSE PARTS. AFTER THE PARTS THE MOTOR NEVER STARTED EVEN WHEN I PUT FUEL IN TBI.
10-28-17 11:56 AM - Post#2712471
Are all the connections tight? So was the distributor was taken out? Are all the fuses ok?
chevylover
Reg: 05-25-04
10-28-17 01:29 PM - Post#2712478
YES EVERYTHING IS TIGHT.
10-29-17 03:15 AM - Post#2712525
Please email me. I'll send you a PDF troubleshooting guide. It will guide step by step on things to check. You'll need a digital voltmeter.
Does it spark? You'll have to test for power at certain points per the PDF guide. My email is under my profile.
PDF file sent. Good luck! Let us know what you find. Post questions too.
Edited by gchemist on 10-30-17 04:16 AM. Reason for edit: No reason given.
chevylover
Reg: 05-25-04
11-08-17 02:20 PM - Post#2713686
HI, I HAVE A FEW QUESTIONS. I HAVE GOOD SPARK. NO FUEL ON PLUGS EVEN IF I PUT FUEL IN TBI ? DIDN'T CKECK THE FUEL LINE PRESSURE YET. WILL IT CAUSE NO FUEL IN TBI IF LOW ? I CHECKED THE INJECTORS WITH A LITE AND THEY ARE WORKING BUT STILL NO FUEL. NO PLACE IN TBI AND ON PLUGS. COULD IT BE THE COMPUTER ? ANY INPUT WILL BE HELPFUL. THANKS WALT
11-08-17 03:14 PM - Post#2713694
How did you check the injectors, noid lite?
chevylover
Reg: 05-25-04
11-08-17 07:55 PM - Post#2713728
Lite with two probes and lite on top.
11-09-17 07:16 AM - Post#2713752
If the injector has 12v to it, ok, the ecu pulses to ground on the other side, so hooked up correctly the lite should flash as the engine cranks.
11-09-17 07:50 AM - Post#2713759
Does the fuel pump still prime for 2 seconds? Verify fuel pressure. Even if the pump primes, fuel pressure can be too low. You can disconnect at the past the filter or TBI.
2blu52
2blu52
Reg: 03-12-02
11-09-17 07:51 AM - Post#2713760
If you got air, and spark then you have no fuel! So identify what is happening with that part of the system.
THOMAS JEFFERSON
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
11-11-17 01:09 PM - Post#2714038
Walt, it’s not the computer. Resist the temptation to replace it.
As mentioned, check your fuel pressure. You need a TBI pressure adapter. Check right after the fuel filter or right at the back of the throttle body. I bought an adapter and a 15psi gauge that stays in place on mine.
Gchemist’s troubleshooting guide is a good thing to have.
Attachment: 2348FC52-C00B-48D0-BDC9-7C7253D903FC.jpeg (465.85 KB) 10 View(s)
Greg
'00 Explorer XLT 4.0 V6 Auto
LMC Trucks
Execution time: 0.353 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:49 AM
