Username Post: 88 S-I0 4.3 HAS SPARK WON'T START        (Topic#347912)
chevylover
Reg: 05-25-04
10-28-17 12:36 AM - Post#2712428
I PUT LOTS OF DIST. PARTS IMPROVED SPARK. BEFORE DOING ALL THIS I PUT FURL DOWN THE TBI AND IT FIRED. AFTER ALL THESE PARTS THE ENGINE WILL NOT FIRE AND TURNOVER. DO YOU HAVE ANY IDEAS? CK. FUEL PUMP IT'S FINE I CAN HEAR IT RUN. ANY IDEAS WILL BE TRIED. THANKS
Senior Chevytalk Moderator
10-28-17 05:36 AM - Post#2712435
    In response to chevylover
If the fuel pump primes and it starts with fuel down the TBI, fuel pressure may not high enough. First, with the key on, check for power at the fuel injectors. Second, ohm check the pickup coil. The pick coil is used by the ECM to fire fuel injectors. The pick up coil should read 500-1500 ohms. If it reads outside that range, it’s bad. The entire distributor has to come out to replace it. I just did an 87 TBI truck. We ended up replacing the entire distributor. You need a special adaptor to test fuel pressure.
Does it have any codes? Email me. I’ll send you a TBI troubleshooting guide.
chevylover
Reg: 05-25-04
10-28-17 08:23 AM - Post#2712452
HI, THE TRUCK RAN FOR A FEW MOMENTS BEFORE I CHANGED ALL THOSE PARTS. AFTER THE PARTS THE MOTOR NEVER STARTED EVEN WHEN I PUT FUEL IN TBI.
10-28-17 12:56 PM - Post#2712471
Are all the connections tight? So was the distributor was taken out? Are all the fuses ok?
chevylover
Reg: 05-25-04
10-28-17 02:29 PM - Post#2712478
YES EVERYTHING IS TIGHT.
10-29-17 04:15 AM - Post#2712525
Please email me. I'll send you a PDF troubleshooting guide. It will guide step by step on things to check. You'll need a digital voltmeter.
Does it spark? You'll have to test for power at certain points per the PDF guide. My email is under my profile.
PDF file sent. Good luck! Let us know what you find. Post questions too.
Edited by gchemist on 10-30-17 05:16 AM. Reason for edit: No reason given.
chevylover
Reg: 05-25-04
11-08-17 03:20 PM - Post#2713686
HI, I HAVE A FEW QUESTIONS. I HAVE GOOD SPARK. NO FUEL ON PLUGS EVEN IF I PUT FUEL IN TBI ? DIDN'T CKECK THE FUEL LINE PRESSURE YET. WILL IT CAUSE NO FUEL IN TBI IF LOW ? I CHECKED THE INJECTORS WITH A LITE AND THEY ARE WORKING BUT STILL NO FUEL. NO PLACE IN TBI AND ON PLUGS. COULD IT BE THE COMPUTER ? ANY INPUT WILL BE HELPFUL. THANKS WALT
11-08-17 04:14 PM - Post#2713694
How did you check the injectors, noid lite?
chevylover
Reg: 05-25-04
11-08-17 08:55 PM - Post#2713728
Lite with two probes and lite on top.
11-09-17 08:16 AM - Post#2713752
If the injector has 12v to it, ok, the ecu pulses to ground on the other side, so hooked up correctly the lite should flash as the engine cranks.
11-09-17 08:50 AM - Post#2713759
Does the fuel pump still prime for 2 seconds? Verify fuel pressure. Even if the pump primes, fuel pressure can be too low. You can disconnect at the past the filter or TBI.
2blu52
2blu52
Reg: 03-12-02
11-09-17 08:51 AM - Post#2713760
If you got air, and spark then you have no fuel! So identify what is happening with that part of the system.
THOMAS JEFFERSON
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
11-11-17 02:09 PM - Post#2714038
Walt, it’s not the computer. Resist the temptation to replace it.
As mentioned, check your fuel pressure. You need a TBI pressure adapter. Check right after the fuel filter or right at the back of the throttle body. I bought an adapter and a 15psi gauge that stays in place on mine.
Gchemist’s troubleshooting guide is a good thing to have.
Attachment: 2348FC52-C00B-48D0-BDC9-7C7253D903FC.jpeg (465.85 KB) 15 View(s)
Greg
'00 Explorer XLT 4.0 V6 Auto
KOOL57
KOOL57
Loc: Fargo, ND
Reg: 01-04-03
02-07-18 08:20 PM - Post#2723706
    In response to CowboyTrukr
Just found the thread.
I have '89 S10. Died going down the freeway. Discovered very weak fuel pressure.
Inside the fuel tank, there is a 2inch long hose connecting the pump to the line that exits the tank. Well, my little hose decided to rot away on the freeway.
Had to drop the tank, but a $.25 hose was all I needed.
"If it ain't got fins, it ain't a real car!
02-11-18 10:02 AM - Post#2724035
    In response to KOOL57
Fuel pressure will drive you nuts without a gauge. Been working on an 87 TBI parked for 8 months. Found it had a bad pickup coil. Fixed it and owner ran it to burn up old fuel. Go back weeks later to finish a tune up and brake work. Darn thing would not idle. Took a while to find the problem. The fuel pump was toast. It would start but not supply enough fuel to keep it running. Timing was all over the place trying to make up for it. Always check fuel pressure.
toro455
toro455
Loc: Western NY
Reg: 06-15-02
02-11-18 12:31 PM - Post#2724064
Understood everyone is focused on fuel but did that set-up have a crank sensor? It's been a long time since I had one go bad so I don't even know if I'm recalling the symptoms well but I think I recall it also acted like it wasn't getting fuel. I cannot recall what part of the system it disabled. Perfectly ok if somebody corrects me if I'm wrong
Good luck,
Scott
02-11-18 03:45 PM - Post#2724094
    In response to toro455
The 87 TBI was not getting a fuel signal. The pickup coil/crank sensor was not working. Big hint was the fuel pump not priming. As soon as a new distributor was plugged in and key turned, the fuel pump primed. Started on its first crank.
Execution time: 0.196 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:02 PM
