Username Post: oil inside intake?        (Topic#347870)
rod
Loc: kingman,az
Reg: 04-29-00
10-24-17 08:17 PM - Post#2712044
my friend has a 355 which keeps sucking oil into the intake manifold. Brian has changed gaskets several times. last week-end he checked the angle on the intake surface of the heads. he said he found it to be 35 degrees [which I think is correct]. the head gasket surface has been milled but it is unknown how much.
some questions: how much can a head be flat milled before the intake surface [either head or manifold] has to be milled? what brand of glue [gasket cement] works best on intake ports. FYI, without ordering something off the internet, the only thing available here is Permatex [or something made by them and sold as a house brand, IE Napa] I have heard water pump silicon works well, but never tried it. the new blue Permatex is absolute JUNK!!!
any other thoughts?
thanks Rod in AZ
Don57
Don57
Loc: Illinois
Reg: 04-28-00
10-25-17 05:10 AM - Post#2712072
    In response to rod
Could it be sucking oil through the pcv valve? Maybe a missing baffle?
Some people have problems with silicone sealer because they don't allow adequate time for it to dry.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
10-25-17 09:11 AM - Post#2712105
    In response to Don57
Edited by grumpyvette on 10-25-17 09:17 AM. Reason for edit: No reason given.
elcamino
elcamino
Reg: 03-30-00
10-25-17 07:02 PM - Post#2712183
    In response to rod
If it's been milled then maybe the intake don't fit anymore. In other words there is a gap between the intake and the heads that's too big for a gasket to seal. He should test fit the intake without any gaskets and check the fit matches. Sounds like the heads may have been cut to much?
There was a episode of Fantom Works (Velocity show) back in 2016 where they had a older (60's) chevy engine like that, burning oil for no good reason. Was the intake that did not fit and it was a original chevy intake. Its was like it shrunk and the gap between the intake and the head was too great to effectively seal.
2017 GMC Sierra Denali Ultimate 6.2L(420hp)/8-sp
2016 Polaris RZR 900 EPS
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
10-25-17 07:22 PM - Post#2712189
    In response to rod
I have had to mill the bottom of the intake to get the gaskets to work
bought a edelbrock aluminum intake one time where the angles on the intake ports were off. milled the intake to correct.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
14 camaro (new)
Execution time: 0.252 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:22 PM
