Username Post: retro fit fuel tank to 56GMC        (Topic#347853)
regan56
regan56
Loc: Regina SK Canada, eh!!
Reg: 12-09-02
10-24-17 07:48 AM - Post#2711948
ok, its getting close to teh time where i can fit a gas tank into my 56 frame. obviously teh behind the seat tank is not an option, and i'm looking to go under the bed between the frame rails. i can go with the filler neck at the rear of the truck, flush with the bed wood.
any options or donors that have been used?
2014 GMC Sierra All-Terrain Sonoma Red Crew
1956 GMC StepSide - in progress
bobschevytrucks.com Ecklers Chevy Trucks LMC Trucks
Nomad Jack
Nomad Jack
Loc: Cape Cod, Ma.
Reg: 03-14-03
10-27-17 09:19 AM - Post#2712356
    In response to regan56
I used a 87 Chevy Blazer tank from Dorman Products (576-321) in my 57 and ran the filler neck up into the rear fender for a more "factory" look.
You can see all the install details at my website http://www.jaxcars.net/rear-suspension-and-g as-tan...
Nomad Jack
55 Nomad
http://www.jaxcars.net/55-chevy-nomad.html
57 3100 Pick-up
http://www.jaxcars.net/57-chevy-pick-up.html
31 LT Truck
http://www.jaxcars.net/31-chevy-truck.html
regan56
regan56
Reg: 12-09-02
10-27-17 03:23 PM - Post#2712394
    In response to Nomad Jack
Nice work..thanks.
WagonCrazy
WagonCrazy
Reg: 06-07-05
10-31-17 01:25 PM - Post#2712850
Nice writeup on your website Jack. Thank you for documenting and explaining all of that.
I'll be doing similar stuff to the 59 Apache Fleetside soon.
monty56
monty56
Reg: 04-26-04
11-02-17 09:04 AM - Post#2713054
Well I sure made a big mistake using the rear fill on mine, I cant get fuel in as it dribbles back out of the neck and onto the ground. I made up a funnel and hose to use but need to re-engineer the filler.
Monty
2001 Chevy Suburban 2500
2009 Saturn Vue w/20's
Monty's 56 Truck
Avatar is my Truck
Execution time: 0.189 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:36 AM
