Username Post: Won't start won't run in rain or moisture        (Topic#347844)
K10Matthews
Loc: Pennsylvania
Reg: 01-18-17
10-23-17 08:16 PM - Post#2711886
I have a 1985 k10 with a 350 and I've been having problems with it running or even starting when it's wet or raining. The only thing I can think of is that there's water getting on the starter and up in the distributor cap. Any input would be really appreciated. thank you
1985 K10
elcamino
elcamino
Reg: 03-30-00
10-24-17 03:29 AM - Post#2711908
    In response to K10Matthews
Moisture is penetrating the ignition wires etc.
We had a truck (DOT survey crew F150) at work that did this. As a last ditch effort to get it started wet/damp day we followed advice of a local mechanic and sprayed the spark plug wires, distributor cap etc with WD40 and it started right up. The WD40 displaced the moisture that was preventing it from starting. Note-Any similar product will work just as well, the mechanic just happened to have a can of WD40 to loan us.
If it starts up after doing this your ignition parts are bad; spark plug wires, coil/coil wire, distributor cap/rotor, battery cables/ground cable etc.
2017 GMC Sierra Denali Ultimate 6.2L(420hp)/8-sp
2016 Polaris RZR 900 EPS
Senior Chevytalk Moderator
10-24-17 04:36 AM - Post#2711915
    In response to elcamino
Yup, moister on ignition parts are not good. WD40 works great.
Keith Seymore
Keith Seymore
Loc: Southeast Michigan
Reg: 09-17-08
10-27-17 10:52 AM - Post#2712361
Yep yep, except in my case it was a '42 Farmall "A".
A spritz inside the distributor cap and it would fire right up (which wasn't trivial, since you would be cranking the thing by hand).
K
Chevelle Intro: http://www.popularhotrodding.com/features/1005phr_...
My Pontiacs: http://forums.maxperformanceinc.com/forums/showthr...
Pickup: http://67-72chevytrucks.com/vboard/showthread.php?...
grs
Reg: 07-04-14
12-03-17 10:09 AM - Post#2716738
I had a 67 Lemans . It would not start when it was raining. When I got it running I sprayed the coil with water and it killed the engine. I replaced the coil an no more problem.
Get it running, and spray the ing parts, and see if you can find the problem.
Execution time: 0.198 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:36 AM
