Username Post: 1950 3100 Dash refurb        (Topic#347828)
baehrelw
baehrelw
Loc: west michigan
Reg: 12-16-15
10-23-17 10:29 AM - Post#2711819
I have the instrument cluster loose under the dash. I want to detach the thermostat and Oil pressure lines and am concerned about damaging them in the process. It appears that they are secured to the dash cluster with a square nut, is it as simple as wrenching it off? I see 2 flat screws on either side of the lines for these gauges and assume they are holding the gauge in the cluster. A little guidance would be greatly appreciated. Thank You.
bobschevytrucks.com Ecklers Chevy Trucks LMC Trucks
10-23-17 11:43 AM - Post#2711837
    In response to baehrelw
The oil pressure line can be disconnected at the gauge end without damage. If you find it easier, you could disconnect the line at the engine instead and pull it through the firewall.
This is not true for the temp gauge. The gauge, line and "bulb" at the engine end are all part of a sealed system. If the line gets broken or damaged at any point, the gas/liquid inside will escape and the complete assembly will have to be sent to a gauge specialist for repair. Remove the square nut at the engine end and carefully pass the line through the firewall as you remove the cluster from the dash.
baehrelw
baehrelw
Loc: west michigan
Reg: 12-16-15
10-23-17 01:36 PM - Post#2711848
Thank You Ray, I followed your suggestions and the gauge is out all in one piece. Any idea how to detach the headlight switch? That is the last item still intact in the dash. I have crawled up under there and see no way to get a wrench on the backside of the dash.
10-23-17 04:50 PM - Post#2711868
Here are two methods, depending on whether you have an OE switch or a replacement. The replacement switches I looked at on ebay have a knob with a setscrew and the OE switches have the shaft and knob made in one piece.
First look for a setscrew on the knob, loosen it and remove the knob. This should expose the switch retaining ring or nut. Hold the switch while you unscrew the retainer and you are done.
If no setscrew, feel around on the side of the switch opposite the terminals until you find a spring loaded button. Push the button in while you pull on the knob. This should let you remove the shaft and expose the retainer.
baehrelw
baehrelw
Loc: west michigan
Reg: 12-16-15
10-24-17 07:14 AM - Post#2711940
Got it, It is out. Thank You again Ray. Cheers!
10-24-17 10:54 AM - Post#2711972
Glad to hear you were able to remove the switch with no problems. Did yours have the setscrew or the button?
Mick53
Platinum Supporting Member
Mick53
Loc: Northern Indiana
Reg: 04-02-16
10-25-17 07:26 AM - Post#2712097
Ray is awesome!
baehrelw
baehrelw
Loc: west michigan
Reg: 12-16-15
10-25-17 11:22 AM - Post#2712128
It had the bottom side button. Switch was installed so that the button was on the side. The truck has an aftermarket heater and I was having a challenge getting it out. Per your suggestion, I looked for a set screw after failing to feel one. It was there, I removed it, but it still did not want to come out. After closer inspection, getting up real close, I detected a wee bit of thread on the shaft (it was a 3 position switch similar to the headlight that you pull out to each position), so I tried to unscrew the knob. Off it came, so now the dash is clear of all installed components and I can remove the 2 coats of paint in preparation for returning it to the original paint color.
I am debating on repaint of the door interiors. Truck was originally red, previous owner repainted in the 1980's to a calf poo brown (inside and out), and then again in 2013 to red. He left the dash and all side panels in the poo brown. The doors interior were repainted to red when the exterior was repainted. The doors look good in red, but conflict with my desire to have the truck original in all aspects. Your thoughts on doing the doors?
10-25-17 12:18 PM - Post#2712134
    In response to Mick53
Mick, thank you for the compliment. CT is the warmest and most "family-like" forum I have ever been on.
WagonCrazy
WagonCrazy
Reg: 06-07-05
10-27-17 05:24 AM - Post#2712334
If it was me, and I was in there redoing the dash paint already, I'd just bite the bullet and prep the doors too and paint them all at one time so that you have a completely matching interior.
Edited by WagonCrazy on 10-27-17 05:24 AM. Reason for edit: No reason given.
Execution time: 0.201 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:51 AM
