Username Post: WTB - 1953 235 flywheel        (Topic#347807)
4oldcars
4oldcars
Loc: Little River, S C
Reg: 08-26-15
10-22-17 08:16 AM - Post#2711688
I have a 53 235 standard shift with a worn out flywheel. "Friend" working on it says he can't find a replacement????? Any info appreciated.
1953 Bel Air Sport Coupe 235/3 on tree
1971 GMC Jimmy 2 wd 68 Chev front clip
1996 Roadmaster wagon
2000 Black Eldorado
10-22-17 08:33 AM - Post#2711692
    In response to 4oldcars
If you have a standard equipment 53 passenger car flywheel, it is the same as 42-up 216. These are easy to find. However, first confirm that you have a 9" clutch. There was also an optional 10-3/4" clutch which uses a different flywheel. That one was scarce in cars, but common in 3/4 ton and larger trucks.
4oldcars
4oldcars
Reg: 08-26-15
10-23-17 05:58 AM - Post#2711797
Mine is 9" and I can't find one. All I can find is the starter ring. Any help appreciated.
2000 Black Eldorado
4oldcars
4oldcars
Reg: 08-26-15
10-23-17 08:12 AM - Post#2711809
I don't know how to delete this, but my problem is solved.
2000 Black Eldorado
11-07-17 09:07 PM - Post#2713629
No need to delete as it will just die on its own.
Execution time: 0.326 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:13 AM
