 Page 2 of 2 <12
Username Post: compression readings        (Topic#347798)
dbgryche
dbgryche
Loc: Shelton WA
Reg: 04-23-15
01-05-18 10:02 AM - Post#2720107
in fact i did, there was a drop in voltage at crank reading 9.7. is this not acceptable?
Don't sweat the petty stuff pet the sweaty stuff
1979 Chevy P-20 292/3 spd, 89 Dodge Ram Charger 318 20 over TBI 4 spd w 5"lift with just added 37/13.5/17 ,
01-05-18 01:23 PM - Post#2720127
    In response to dbgryche
A voltage drop while cranking is pretty much to be expected. I don't think it will be enough to prevent the ignition system from working, but there is an easy enough way to find out.
You will need jumper cables and a separate 12V battery or another vehicle with a battery you can connect the cables to. On your truck, disconnect the existing wire from the coil and connect the (+) jumper cable to the same terminal you removed the wire from. Connect the (-) jumper cable to the (-) battery cable on your truck or to any clean spot on the engine.
Now crank the engine again. If still no spark, you know that voltage drop is not causing your problem. Unfortunately, I do not have any other suggestions for you to try.
dbgryche
dbgryche
Loc: Shelton WA
Reg: 04-23-15
01-06-18 12:24 AM - Post#2720185
will try tomorrow when i get it back in the garage
 Page 2 of 2 <12
Execution time: 0.193 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:07 PM
