Username Post: 1963 Suburban rear barn door latch        (Topic#347795)
l4stout
Loc: Missoula, Montana
Reg: 07-26-07
10-21-17 01:39 PM - Post#2711613
Does anyone know of a source for a 1963 Suburban rear barn door latch? I just bought the Burb and the right rear corner was hit breaking part of the rear door latch on the right door. The bar the latch connects to is fine. I was going to weld onto the ear and grind to fit but the back side of the latch is about worn out as well so I would rather replace if possible. I have been looking and found a lot of front door latches but not so much for the back. Were these latches used in anything else? I feel like I have seen them on maybe a Willys?
Thanks for any info.
Old Iron makes me happy. 63 Suburban 4x4, 66 Chevy C10 and 65 GMC
bobschevytrucks.com Ecklers
l4stout
Reg: 07-26-07
11-10-17 07:34 AM - Post#2713887
    In response to l4stout
A quick follow up on the door latch. I ended up spending a couple of hours with a wirefeed welder and a file on the front part of the door latch and the two catch points inside the door and it now works fine. Given the lack of response, I am guessing there are none available unless you found a NOS somewhere.
Execution time: 0.165 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:30 AM
