Username Post: Sound deader or undercoat        (Topic#347753)
Frankman
Gold Supporting Member
Frankman
Reg: 09-25-17
10-18-17 08:32 PM - Post#2711322
So I'm looking for info on sound deader, is it all about the same or is there one that's better than others.
Anonymous
10-20-17 02:09 PM - Post#2711517
    In response to Frankman
There is sound deadener and sound absorber. Not sure which one you need.
For sound deadener, it's hard to beat Dynamat.
A little pricey however. As an alternative I used Noico 80 mil in my trunk to improve sound system quality and isolate noise from the electric fuel pump.
Frankman
Frankman
Reg: 09-25-17
10-25-17 01:43 PM - Post#2712141
    In response to
Ok thanks I'll check that out.
asbicca
asbicca
Loc: Southern California
Reg: 07-18-03
10-26-17 03:15 PM - Post#2712264
Do a search for FatMat Self-Adhesive Butyl MegaMat Sound Deadener, 70 mil Thick,on Amazon.
It is what I used and it worked great.
Look for the one with the aluminum top and it also acts as a heat shield.
http://s2.photobucket.com/albums/y40/asbicca/55 %20...
Frankman
Frankman
Reg: 09-25-17
10-26-17 06:15 PM - Post#2712293
    In response to asbicca
I'll do that it looks like you did a great job on your 55 chevy, did you have to use a heat gun on it or not. sorry for the slow response, went hunting I should have stayed home and worked on the car.
asbicca
asbicca
Reg: 07-18-03
10-26-17 08:50 PM - Post#2712302
The material is pretty pliable so no need for a heat gun.
Frankman
Frankman
Reg: 09-25-17
10-29-17 07:03 PM - Post#2712635
Ok thanks.
Andy4639
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
11-21-17 03:51 PM - Post#2715238
I need to do this also to the 56. Yours looks great.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
4dr 57
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
12-07-17 05:22 AM - Post#2717160
wow, why just install quiet/stock mufflers and/or a good pad under the carpet...oh well.
It's all good. mostly
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
12-07-17 09:01 PM - Post#2717256
    In response to 4dr 57
All that insulation really aids the efficiency of the A/C.
Bruces 57
Reg: 01-03-07
12-20-17 07:30 AM - Post#2718544
    In response to 5Larry7
Hello;
I must ad a word of caution on installation of some of these foil sticky (butyl) sound insulations!!
The foil edges are sharp as razor blades! Be careful with handling that stuff! Or especially removing same!!!!
Don't ask me how I know!
Bruce
Frankman
Frankman
Reg: 09-25-17
12-20-17 07:48 PM - Post#2718631
    In response to Bruces 57
Well thanks for the heads up Bruce, I will be careful. And thanks for the response. So do you live Bruce, I live in brighton Colorado about 20 miles north of Denver.
Bruces 57
Reg: 01-03-07
12-28-17 06:21 AM - Post#2719194
Hello;
Sorry, Im in California
Also, the "jute" style pad also works really good for noise and heat and is very cheap! But it takes a bit more effort to get it to "lay down" really good! (lots of contact spray needed}
It is easier to use the foil style sound deadner as it already has a stickey side!
Bruce
Frankman
Frankman
Reg: 09-25-17
12-28-17 06:48 PM - Post#2719276
Thank you Bruce.
Nick P
Nick P
Loc: De Queen, Arkansas
Reg: 10-15-03
02-09-18 07:12 AM - Post#2723859
Not certain of the effectiveness but saw this the other day: http://store.secondskinaudio.com/?gclid=Cj0KCQiAwK...
Frankman
Frankman
Reg: 09-25-17
02-11-18 08:28 PM - Post#2724127
    In response to Nick P
Thank you nick worth looking into.
Execution time: 0.25 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:44 AM
