Username Post: Sound deader or undercoat        (Topic#347753)
Frankman
Gold Supporting Member
Frankman
Reg: 09-25-17
10-18-17 08:32 PM - Post#2711322
So I'm looking for info on sound deader, is it all about the same or is there one that's better than others.
Anonymous
10-20-17 02:09 PM - Post#2711517
    In response to Frankman
There is sound deadener and sound absorber. Not sure which one you need.
For sound deadener, it's hard to beat Dynamat.
A little pricey however. As an alternative I used Noico 80 mil in my trunk to improve sound system quality and isolate noise from the electric fuel pump.
Frankman
Frankman
Reg: 09-25-17
10-25-17 01:43 PM - Post#2712141
    In response to
Ok thanks I'll check that out.
asbicca
asbicca
Loc: Southern California
Reg: 07-18-03
10-26-17 03:15 PM - Post#2712264
Do a search for FatMat Self-Adhesive Butyl MegaMat Sound Deadener, 70 mil Thick,on Amazon.
It is what I used and it worked great.
Look for the one with the aluminum top and it also acts as a heat shield.
http://s2.photobucket.com/albums/y40/asbicca/55 %20...
Frankman
Frankman
Reg: 09-25-17
10-26-17 06:15 PM - Post#2712293
    In response to asbicca
I'll do that it looks like you did a great job on your 55 chevy, did you have to use a heat gun on it or not. sorry for the slow response, went hunting I should have stayed home and worked on the car.
asbicca
asbicca
Reg: 07-18-03
10-26-17 08:50 PM - Post#2712302
The material is pretty pliable so no need for a heat gun.
Frankman
Frankman
Reg: 09-25-17
10-29-17 07:03 PM - Post#2712635
Ok thanks.
Andy4639
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
11-21-17 03:51 PM - Post#2715238
I need to do this also to the 56. Yours looks great.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
4dr 57
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
12-07-17 05:22 AM - Post#2717160
wow, why just install quiet/stock mufflers and/or a good pad under the carpet...oh well.
It's all good. mostly
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
12-07-17 09:01 PM - Post#2717256
    In response to 4dr 57
All that insulation really aids the efficiency of the A/C.
Execution time: 0.38 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:35 PM
