Username Post: Buffing New Paint        (Topic#347731)
Jack Crain
Loc: Wichita Falls, Texas
Reg: 07-24-11
10-18-17 05:13 AM - Post#2711219
How long after applying new paint can it be wet sanded and buffed? I did some rust repair work on my 46 Fleetmaster and I need to work on the paint. Oh, it is Black Acrylic Enamel
thanks
1946 Fleetmaster 4-dr Sedan with '57 235
Fenton Dual Exhaust and Intake
Dual Carter Webbers 2 barrel Carbs
HEI ignition
Front Disk Brake
T-5 Tranny
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
10-18-17 07:45 PM - Post#2711311
    In response to Jack Crain
You can always check what the manufacture recommends for their paints...should be a "P" [product] sheet out there somewhere on line. What brand?
But speaking generally, I would wait a week. Then start in an area that is not obvious. If the paint is balling up on the paper, you need to wait longer. Good to put a little soap in the water as well and sand with a block or pad.
1951 Fleetline
Jack Crain
Reg: 07-24-11
10-19-17 01:14 PM - Post#2711375
    In response to RAM_51
Thanks Ram.
HEI ignition
Front Disk Brake
T-5 Tranny
RAM_51
RAM_51
Reg: 12-28-02
10-29-17 04:01 PM - Post#2712590
No problem
1951 Fleetline
Execution time: 0.251 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:23 AM
