Make sure the factory fans are working correct now they might turn on but when going bad they will drag and not turn as fast also make sure your radiator isn’t plugged up or clogged up with bugs and mud and so on another thing make sure your water hoses are in good shape old ones can collapse and not let the water flow correct even a bad water pump can fool one big times the impeller might not be turning as it should that can happen as well if I were you I would install a mechanical water gauge to know for sure what the temp is and make sure the timing is where it should be meaning the engine timing one last thing make sure the upper radiator hose is lower than the radiator fill cap.
Ok I messed up some persons car is running hot so I just put down some things to check sorry for the mess up.
Edited by Gmctrucks on 10-18-17 05:02 AM. Reason for edit: No reason given.
What?
Are you having problems, or trying to answer someone else's question?
I don't understand anything you wrote.
Griff
if you're gonna be a bear.....................
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
