Username Post: Power Steering Pump        (Topic#347719)
Reg: 08-09-17
10-17-17 02:27 PM - Post#2711166
On a 1966 427 with power steering, how do you add or check fluid without removing or moving the alternator??? It sits directly under the alternator mounting bracket.
Thank you
Loc: Vacaville, CA
Reg: 02-19-04
10-17-17 07:55 PM - Post#2711189
    In response to 1spacover
On our '67 BB, there is enough room to tilt the lid/dip stick to get it out. If that doesn't work, I had to cut the tip off of the dip stick on my modified '72 to get it off. Still tight, but that may be what you need to do.
38 & 39 2dr sedan, 41 coupe, 54 convertible, 56 Nomad, 57 210 2dr sdn, 70 Camaro RS, Corvettes; 57, 61, 65 396 coupe, 67 427 convert, 69 & 72 T-top, 88 coupe,91 ZR-1, 07 Z06, 16 Z06, 07 Silverado, 09 BMW 135i vert.
Execution time: 0.206 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:52 AM
