Username Post: Power Steering Pump        (Topic#347719)
1spacover
Reg: 08-09-17
10-17-17 02:27 PM - Post#2711166
On a 1966 427 with power steering, how do you add or check fluid without removing or moving the alternator??? It sits directly under the alternator mounting bracket.
Thank you
bowtiefan
bowtiefan
Loc: Vacaville, CA
Reg: 02-19-04
10-17-17 07:55 PM - Post#2711189
    In response to 1spacover
On our '67 BB, there is enough room to tilt the lid/dip stick to get it out. If that doesn't work, I had to cut the tip off of the dip stick on my modified '72 to get it off. Still tight, but that may be what you need to do.
Ken
38 & 39 2dr sedan, 41 coupe, 54 convertible, 56 Nomad, 57 210 2dr sdn, 70 Camaro RS, Corvettes; 57, 61, 65 396 coupe, 67 427 convert, 69 & 72 T-top, 88 coupe,91 ZR-1, 07 Z06, 16 Z06, 07 Silverado, 09 BMW 135i vert.
http://www.picturetrail.com/ken58
Execution time: 0.352 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:41 PM
