Username Post: Armoured Ign Housing ?'s        (Topic#347659)
42Special
42Special
Loc: NW
Reg: 09-24-16
10-13-17 08:02 PM - Post#2710796
Does anyone have a pic of the ignition wire housing with the special grommet installed. And how do you go about installing it on the housing? One end has the ign. switch attached and the other has the metal cap for the ign. coil attached. Are either removable from the housing?
42Special
42Special
Loc: NW
Reg: 09-24-16
11-11-17 02:03 PM - Post#2714046
    In response to 42Special
In case anyone is wondering about this. I was able to gently squeeze the crimped end at the coil end of the cable and pull on it while unscrewing it off the armored cable and then simply reversing to put it back together again.
Execution time: 0.433 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:58 PM
