Username Post: 71 factory ac        (Topic#347643)
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
10-12-17 03:21 PM - Post#2710679
i am currently working on a 71 with factory ac and trying to get it to cool properly. one of the problems i have is that what i think is the fresh air door under the grille by the windshield is broken.
what is the correct name for this door?
where might i find one and what would be the best way to replace it?
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
14 camaro (new)
JimKshortstep4x4
Chevytalk Moderator & "14th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
10-12-17 03:57 PM - Post#2710683
    In response to 62chevy427
The Service Manual calls the "door" an outside air inlet valve. It is vacuum operated and should close to recirculate the air to get maximum cooling.
The usual problems that happens to the "valve" (I call it a "door" is the shaft breaks or the vacuum motor fails. Of course a leakage of vacuum can cause control problems.
The vacuum motor has to be disconnected and is accessible under the hood. To get at the door, the cowl has to be removed. There should be a spring hooked to the door that holds it open, (the vacuum motor closes the door).
I am not sure where to buy the "door".
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
10-12-17 07:00 PM - Post#2710698
thanks,jimKshortstep4X4. the door is broken. the shaft broke off. the actuator still works good,especially since i repaired the vacuum hoses.
i finally got the ac pretty cold by running it slightly low on freon, but it sucks in haot air.i may try to just fix the door so that it is sealed if i can not find one.
95 impala (new)
14 camaro (new)
JimKshortstep4x4
JimKshortstep4x4
10-13-17 03:34 PM - Post#2710768
Depending on how and where the shaft is broken, you may want to consider repairing it with epoxie.
I have one that has been repaired, and it looks like a good way to repair it.
I can text you a picture if you like.
I did find out that LMC used to carry them but their site does not list them.
Andy4639
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
10-16-17 05:50 AM - Post#2711001
Manes truck parts sell it.
Best mode I ever did to my 71 was seal it off completely.
http://www.manestruckparts.com/store/store_product...
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
10-20-17 06:34 AM - Post#2711477
    In response to Andy4639
thanks,andy4639.
i just ordered one of the doors.
if it was my truck i probably would just close it off too, but it is a customers.
of course if this still leaks air, i may still do that.
thanks again
95 impala (new)
14 camaro (new)
Andy4639
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
11-14-17 05:11 PM - Post#2714387
Another trick to get as much cooling as possible is put a manual hot water shut off in the heater hose. If the vacuum valve lets a little water through into the cab it will make the cooling less. I got 5* more out of mine by doing this.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
11-18-17 08:13 AM - Post#2714840
I put a brass valve in-line on mine and what a difference it knocked down on the heat coming into cab.
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327
Execution time: 0.238 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:19 PM
