Username Post: BBK question        (Topic#347635)
PMBell357
Reg: 03-24-16
10-11-17 05:03 PM - Post#2710577
I will be running a 20 or 22 inch wheel on my SS vert. I will be on air ride (probably makes no diff). With those known factors, I am finding online (and calling companies) that state an 11" rotor will work just fine with my stated wheel size......but I have a guy whom I was going to purchase the BBK from initially saying it won't work with my wheels. he states YES it will fit, but its not "correct" for your vehicle and I need 13' in front, and 12" in back.
My question...how much of a gain would there be using a 13" rotor over an 11" rotor? Is there a substantial gain or is the big rotor just the latest fad....which is a BIG cost difference as well.
Thx for any help I can on this topic.
nicke
nicke
Loc: Spokane, Washington
Reg: 01-06-12
10-11-17 05:43 PM - Post#2710582
    In response to PMBell357
It really depends on how you'll use your car.
In my opinion, unless you plan on doing some serious autocross or road racing, 11" rotors on the front should be just fine. That being said, a larger rotor can mean more efficient braking, all other factors equal, but on a street driven car, you likely wont see much of a performance difference. Either setup is a huge improvement from drum brakes.
I do have 13" front rotors, and they work well. I hope this helps.
-Nick
My 65' Impala SS LS Swap
6.2L LS ,4L80E, 3.73 gears, disc brakes
PMBell357
Reg: 03-24-16
10-12-17 03:57 AM - Post#2710606
    In response to nicke
Thx Nicke....I recall you saying you ran a set from POL. Do you still have the specifics of kit? What did you run in rear?
Edited by PMBell357 on 10-12-17 03:58 AM. Reason for edit: No reason given.
65_Impala
Reg: 12-29-02
10-12-17 06:15 AM - Post#2710618
The bigger brakes will fill the wheels more but the cheaper 11" kits with the large caliper will work fine. Just avoid the smaller metric caliper.
nicke
nicke
Reg: 01-06-12
10-12-17 07:28 AM - Post#2710630
Yep, exactly.
Here is the kit I'm running.
I'm still running the stock drum brakes as I haven't ever felt the need to go to disks back there. If I did, it would be for looks, as I feel like I have all the stopping power I'd ever need.
Hope this helps!
-Nick
10-12-17 10:04 AM - Post#2710645
Keeping everything else equal, you lose some braking performance as the tire (not wheel) O.D. increases. Think of it as a reduction in leverage directly proportional to the increase in radius.
In other words, even if you are totally satisfied with the performance of your present brakes, you may not be happy with them when you go from stock size wheels (or whatever size you have now) to 22" wheels because of the increase in tire O.D. To retain your previous braking performance, you will have to install "better" (which could mean larger diameter) brakes.
I hope this makes sense, but if it doesn't, feel free to ask and I will try to come up with a better way of explaining it.
Crusty66
Crusty66
Loc: Albany, eNZed
Reg: 11-04-12
10-12-17 12:33 PM - Post#2710661
From my personal experience-
the 11" is a waste of time - the braking performance is inadequate for such a large heavy car. I ran the 11" with the large caliper & was not happy. Where I live we have very twisty roads & got a bit of fade with heavy use. I fitted the CPP big brake 13" kit & transformed the braking, well worth the price difference.
If you search back through the forum, I'm sure there are other posts saying the 11" rotors are inadequate.
Beware though that the 12" CPP rear kit with the Lincoln style calipers might have clearance issues with the caliper hitting the frame. I had to remove mine & fitted Wilwoods to the rear.
The Wilwoods with the drum type e-brake is much better.
Steve
1966 Caprice 396 496 496mkII TH400
PMBell357
Reg: 03-24-16
10-13-17 06:35 AM - Post#2710724
Perfect sense.
PMBell357
Reg: 03-24-16
10-13-17 06:37 AM - Post#2710725
    In response to Crusty66
ahhh so this is useful as I was about to call CPP for a talk concerning their 13' BBK. Thx.
PMBell357
Reg: 03-24-16
10-13-17 06:40 AM - Post#2710728
    In response to 65_Impala
yeah...I've seen a few of those trying to get passed off. This is a cutthroat game....almost like vehicle transportation hahah
Execution time: 0.283 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:13 PM
