Username Post: esc module        (Topic#347630)
teddybear15
teddybear15
Loc: Thatcher Az
Reg: 08-25-15
10-11-17 04:40 PM - Post#2710568
is there a way to test the esc module??
1988 chevy S 10 4x4 had a 4.3 swap to a 1988 chevy 5.7 engine came out of a K 1500 truck 4x4
Senior Chevytalk Moderator
10-11-17 05:39 PM - Post#2710575
    In response to teddybear15
What year or generation? Is communication possible? If not, the circuit could be unpowered. Can you provide more information.
teddybear15
teddybear15
Loc: Thatcher Az
Reg: 08-25-15
10-12-17 09:04 AM - Post#2710632
on my 1988 chevy s 10 with a 1988 chevy 5.7 i replaced the dis. ecm knock sensor the truck still set a code 42 and at idle wants to die. all the wires look good.
teddybear15
teddybear15
Loc: Thatcher Az
Reg: 08-25-15
10-12-17 04:16 PM - Post#2710678
thank you for the infor. i think i found the problem
the wires going from the coil to the dis. are bad.
10-15-17 05:11 AM - Post#2710900
Coil to distributor wires can be a problem. Especially pickup coil wires.
Did you replace any parts? How is it running now?
Execution time: 0.245 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:59 PM
