Username Post: power steering leak        (Topic#347627)
old apache61
Reg: 08-07-15
10-11-17 09:02 AM - Post#2710526
I have a 1957 chevy belair. I have a leak in the power steering pump. I can't seem to find it. The pump isn't leaking and the hoses seem to be ok. Any thoughts?
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
10-11-17 09:09 AM - Post#2710528
    In response to old apache61
clean everything. put die for ultraviolet light in it. run it and check it with the light. the leak will show up kind of yellow looking.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
14 camaro (new)
10-11-17 10:51 AM - Post#2710538
    In response to 62chevy427
The O-ring for the reservoir may be leaking. Link to pump seals.
Jalapeno
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
10-11-17 05:56 PM - Post#2710583
Another possibility is the vent in the pump cap is plugged. If the PS system is even slightly overfilled it can capillary up the fill spout.
The vent is at the rivet in the center of the cap. Where the dipstick turns under the rivet there is a small notch on the dipstick, make sure that's clear. Soak the cap in solvent and poke a fine wire at the notch, do this for several days, keep poking at it.
Jalapeno
old apache61
Reg: 08-07-15
10-12-17 03:45 PM - Post#2710681
    In response to acardon
There are no visible wet spots around the pump or reservoir at all. There is some fluid underneath on the frame. I see no indication by sight or touch that the hoses are leaking either.
Jalapeno
Jalapeno
Reg: 04-30-00
10-12-17 04:25 PM - Post#2710685
OK, so no wetness at the pump. Not trying to be a wise a$$, but why do you think the pump is leaking?
Where on the frame is it wet with ATF?
Thinking about it, let's back up a bit. Do you have an original pump on the back of the generator? I bet not, I bet you have a later style engine mounted pump. A later pump sits right above the crossmember, which is where I suspect the ATF is.
Jalapeno
old apache61
Reg: 08-07-15
10-13-17 03:56 AM - Post#2710711
    In response to Jalapeno
Yes this is the original style pump that connects to the back of the generator. I know it is or has been leaking. I had a bad brake booster so I had the Chevrolet dealer install a new one. The new booster was deeper than the original one so they rolled the pump toward the fender to clear the booster which put the fill tube directly under the booster line so you had to disconnect the generator to roll the pump over about and 1" or so to check the fluid. Anyway when I drove the car home the power steering was really whining when I mad any turns. I checked the fluid it was low. I refilled it, drove it again and checked fluid. It was low again. I had placed a pan under car to catch any fluids. There was fluid on the pan. Dealer says they didn't disconnect the pump.
Jalapeno
Jalapeno
Reg: 04-30-00
10-13-17 07:56 PM - Post#2710795
Very strange.
Can you post a pic of the gen/pump and how it's situated? Is the fill spout pointing mostly up, or is it sideways?
Jalapeno
Execution time: 0.352 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:47 AM
