Username Post: Electric fuel pump? 80 1/2 ton Silvarado        (Topic#347624)
4dr 57
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
10-11-17 08:19 AM - Post#2710518
A Mechanic told me the other day that there was an electric pump that will just bolt in place of my stock fuel pump.
Then turned away and went back to work. Its a busy shop and I didn't pursue the question.
FYI My f/p has 3 connections; 2 hoses and one steel line connection.
The smallest diameter hose meets a 1/4"steel line. I have no idea where it goes except that it heads back to wards the rear on the right side.
Neither of my 2 books shows anything about it.
Another line is from the rear to the pump also 3/8"? The last one goes to the carburator.
Would any one know of such a pump? I would gladly, no make that direly want to install one!
Thanks!
LMC Truck
10-11-17 12:00 PM - Post#2710544
    In response to 4dr 57
If you presently have a mechanical fuel pump which is bolted onto the engine and driven by the camshaft, you need to find out what your mechanic is smoking and try some. I am not aware of any electric fuel pump which mounts on the engine as he described.
Your 1/4" line is a return to the tank. The pump has more capacity then is needed by the engine most of the time, so fuel in excess of the engine requirements is recirculated. This also helps to keep vapor bubbles out of the line going to the carb.
Electric pumps do exist of course, and the ones which don't install in the tank typically bolt to the frame. If you install an electric pump without a return port you might also want to add an external pressure regulator with a return port or at least a filter with a return port. The fuel recirculation is also beneficial in keeping the pump motor cool.
4dr 57
4dr 57
Reg: 11-10-04
10-12-17 05:02 AM - Post#2710609
RAYCOW Thanks for your input as your suggestions caused me to search LMC Truck's catalog. Lo and behold, they have something they call a fuel pump control module, which may be a way of losing the cold start blues.
An installation diagram for it will take a call to LMC as there's nothing listed in their catalog other than the part and its 5 assorted lines.
After reading the short blurb about it there is a distinct advantage to using it rather than a simple on/off electric pump because it shuts off when the motor stops running, so it must be hooked in to the tach circuit rather than the ignition switch. Looks like what I'm looking for.
Stanley
Liberty Valance
Liberty Valance
Loc: Euless,Texas
Reg: 07-21-14
10-12-17 06:08 AM - Post#2710617
Thanks!
Which vehicle are you wanting this for? I had thought about this myself, but have not moved forward yet.
1974 Cheyenne 10 LWB 350/TH350
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
10-16-17 06:30 PM - Post#2711076
    In response to Liberty Valance
An electric pump sucks fuel poorly and pushes fuel well....therefore, unless you want it to vaporlock, the electric FP needs to be mounted as close to the tank as possible.
Keith Seymore
Keith Seymore
Loc: Southeast Michigan
Reg: 09-17-08
10-27-17 09:47 AM - Post#2712359
    In response to Stinky
I have had a tank mounted electric pusher pump (Holley "red" I believe) on my high performance vehicles for many many years.
I usually wire it to a toggle switch for priming the engine before firing, or during periods of high demand (like a burnout or quarter mile blast). During the rest of the time I motor around on the engine mounted mechanical fuel pump. No issues, other than you do need to remember to turn it off when you want it off.
It's been on my '65 GTO since the mid to late 1960s. It's a 360 HP tripower and has gone 12.20'as in the quarter.
I have had this on my Chevelle since the late 1970's. It is approximately 1000 HP and has gone 9.80's at 136 mph.
K
Chevelle Intro: http://www.popularhotrodding.com/features/1005phr_...
My Pontiacs: http://forums.maxperformanceinc.com/forums/showthr...
Pickup: http://67-72chevytrucks.com/vboard/showthread.php?...
LMC Truck
Execution time: 0.266 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:22 PM
