Username Post: Big block engine mounts        (Topic#347599)
Am4wag
Reg: 11-19-15
10-10-17 09:15 AM - Post#2710406
On my '69,I "caught wind" of possibly needing taller/different engine frame mounts due to switching from a 350sbc to Gen.VI 454bbc with Hooker Super Comp.headers and Moroso oil pan.I've looked all over and all I can find is the same frame mounts fit small or big block.Any input would be helpful,as I'd hate to have the bb in the hole just to find out it won't set in.
The bearer of gossip is a small untrustworthy person who takes delight in someone else's problems. Avoid them.
Let's all make the day count. - Charlie Daniels
SSuper Dave
Loc: Pearland TX
Reg: 10-02-05
10-10-17 12:27 PM - Post#2710422
    In response to Am4wag
IIRC, frame mounts are the same for a 350 or a big block. A factory 307 car uses different frame mounts, and a big block can be successfully installed using 307 mounts on the engine side. (I've done two) There are now interlocking 307 engine side mounts made.
1968 Caprice coupe, 327/275, TH400, Ash Gold/Ivy Gold, Tach Dash, Tilt, Buckets, Console, AM/FM, Rear Defog, Disc and Rallys.
1970 El Camino, 350, TH400, 12 bolt posi, a blank slate!
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
10-13-17 02:41 PM - Post#2710761
    In response to SSuper Dave
Am4wag
Reg: 11-19-15
10-24-17 06:55 AM - Post#2711938
This elco was originally a 6 cyl.Fast forward to 5 years ago,my cousin had a really powerful bbc in it w/4-speed.Later he put a sbc in it,which is what is in it now,then to my total shock,he passed away.I bought it when it became available,so here we are.
I'll be swapping out the sbc for a bbc.From what I'm digesting,Camaros and Corvettes use different/taller frame mounts for sbc/bbc,and the frame mounts are the same for Chevelles,Elcos.So it looks like all I need to get is some good poly motor mounts,right?
johnhem
johnhem
Loc: Winona, Tx,
Reg: 06-30-01
10-24-17 06:58 PM - Post#2712038
Attachment: 68-72_frame_mounts.jpg (28.03 KB) 14 View(s)
John H
72 Chevelle-454-4speed
Soon to be 502-5speed
http://www.502malibu.com
2014 GMC Sierra SLT Double Cab
Give Free Food To Rescued Animals Daily
HERE
Am4wag
Reg: 11-19-15
10-31-17 05:50 PM - Post#2712878
    In response to johnhem
I ordered a set of frame mounts from Auto Metal Direct for a 1969 El Camino.Now,my big question,will I need tall and narrow or short and wide motor mounts?
johnhem
johnhem
Loc: Winona, Tx,
Reg: 06-30-01
11-01-17 08:54 AM - Post#2712936
I used the locking type by Balkamp. Check around because the prices vary a lot. Mine were $10 apiece. NAPA gets almost $50. Got mine at O'rielly.
Attachment: NWMDC.jpg (12.31 KB) 13 View(s)
John H
HERE
Edited by johnhem on 11-01-17 08:55 AM. Reason for edit: No reason given.
