 Page 2 of 2 <12
Username Post: Help cool my BBC        (Topic#347587)
toro455
toro455
Loc: Western NY
Reg: 06-15-02
10-12-17 09:19 PM - Post#2710700
    In response to farm rat
Farm rat,
You mentioned you're using straight water. You do really need a corrosion inhibitor package else you will start to notice your coolant (water) will start to turn red-browm rust color. You may also start to see the radiator filtering out corrosion coming from inside of the block.
There was a point made regarding oil and trans oil coolers. If you add those in front of the radiator (traditional place to mount them) the heat extracted from the oil increases the air temp which then continues through the radiator. If there are other areas you could mount them where they would still get some airflow without raising the radiator incoming air that idea could help. Also increasing the sump capacity (deeper pan) will decrease oil temps.
While discussing a rise in air temp another possible issue with your electric fans, and no shroud, is re-circulation of hot air. It is possible, especially if the area behind the fans does not have much escape path, the air going through the radiator is circling around and coming through multiple times. I've seen air temps increase by 60 degrees F in a situation like that.
Good luck,
Scott
SleeperSS
Loc: Spanaway, Wa
Reg: 10-17-04
10-12-17 10:02 PM - Post#2710702
What kind of vehicle are you working on?
U.S.C.G. "So others may live"
'96 S-10 SS
'02 BlaZeR2
farm rat
Reg: 09-13-16
10-19-17 07:47 AM - Post#2711351
    In response to SleeperSS
1982 Chevy K10
Senior Chevytalk Moderator
10-22-17 04:45 AM - Post#2711661
Is the original cat still on it? Heat will build up if it's starting to collapse.
Good truck cooling info: http://www.off-road.com/trucks-4x4/project/pr oject...
Edited by gchemist on 10-22-17 04:48 AM. Reason for edit: No reason given.
 Page 2 of 2 <12
Execution time: 0.168 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:11 AM
