bluesfella
Loc: Tallahassee FL
10-08-17 10:30 AM - Post#2710138
So, I put THIS CRATE MOTOR in my '55 Chevy recently. I had to get a block-mounted starter because I'm using the smaller 153 tooth flywheel, so I got THIS ONE.
It seems like the starter gear is too close to the flywheel, so I added both of the shims in the package to bring the gear back a bit. But still, every time I hit the key, the gear just hits the flywheel and doesn't engage. I just ordered a shim kit, but I'm thinking that if I have to add that many shims, I must have the wrong starter? Or something else is wrong?
I haven't had a chance to precisely measure how far away the gear is from the flywheel (the car is at my buddy's garage), but I'll check that as well when the shims get here.
What am I missing?
10-08-17 03:10 PM - Post#2710167
In response to bluesfella
On the page you linked for the starter, two user reviews reported the exact same problem you are having. One of the users said he had to return the starter, and I assume the other did, too.
One possible explanation is that the page says the knurl on the included mounting bolts DOES NOT extend into the counterbores in the block. Since the increased diameter of the knurl is the ONLY thing holding the starter in alignment on a block mounted starter (now you know why I dislike block mounted starters), that may be the cause of your problem. Assuming that the block and the starter are both machined correctly, you might want to see if you can find the correct mounting bolts before you return the starter to Summit.
bluesfella
Loc: Tallahassee FL
10-08-17 07:36 PM - Post#2710209
I think the knurling does go up into the block, but I will check that, thanks!
I thought I had to go block-mounted because my flywheel is the smaller 153 tooth and my bellhousing was made for only the larger 168 tooth.
Edited by bluesfella on 10-08-17 07:37 PM. Reason for edit: No reason given.
10-09-17 12:41 AM - Post#2710236
You're right. If you want to run a 153 tooth flywheel you don't have any choice about the starter. It has to be block mounted. IMO it was still a bad design choice by GM just to save a buck. AFAIK, no other US car manufacturer uses this design.
66cayne
Reg: 08-06-08
10-09-17 05:36 AM - Post#2710253
contact the crate motor manufacturer and find out what starter they recommend.
bluesfella
Loc: Tallahassee FL
10-09-17 07:32 PM - Post#2710341
So I went out to the garage tonight, and sure enough, it won't work. I had purchased an additional shim kit for it, so I have all three shims (the ones that move the gear back, not the normal starter shims that move the whole starter down), and it still won't line up correctly.
I took a video of it so you can see what it does: https://youtu.be/rXorKGg2TbA
Raycow, you were right about the knurling not going up into the block, but honestly I don't see how even that would help this line up.
I even put every "normal" starter shim I could find in there, it ended up being 7 of them. Hoping that would move the starter down enough, but still no go. If I manually move the flywheel a bit so the teeth line up, it will engage, but then it's too tight to disengage. And as soon as it finally disengages, it's back to hitting the flywheel again.
Am I just naive for thinking "how hard could this be"? There are only two options for flywheel size, and this starter was designed to work with either. (Two sets of bolt holes.) How can you buy a starter that's designed to work on an SBC with a 153 tooth flywheel, and it not work?
66cayne, I have emailed the crate motor company to ask them, but no response yet.
Is there a block-mounted starter you guys know of that actually works with a 153 tooth flywheel?
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
10-09-17 08:17 PM - Post#2710348
Does the starter ever spin? Have you bench tested the starter?
55 Shaker
Loc: north central IL.
Reg: 03-13-06
10-09-17 08:20 PM - Post#2710349
Vance. It's been quite a few years and beers ago. But I think a 1979 Chevy Malibu 305 cu. in. had a 153 tooth flex plate, fly wheel. The factory starters had the mounting bolt straight across from each other. Go to an auto parts store and look up a starter for that.
A factory starter for a 168 tooth flywheel will have the mounting bolts staggered. Hope this helps.
Brian
The older I get, the more dangerous, I am !!!! |
10-09-17 08:33 PM - Post#2710354
In response to aghaga
I think Aghaga is on the right track. It looks like the solenoid is not holding the gear in the flywheel. The "hold" winding in the solenoid may be open. As soon as the "pull-in" winding starts spinning the motor the solenoid drops the gear back out. As mentioned, bench test it.
10-09-17 10:32 PM - Post#2710368
I know this sounds crude, but could you loosen the bolts slightly, then "pry" the starter sideways (toward the outside of the car) and retighten the bolts?
65_Impala
Reg: 12-29-02
10-10-17 05:47 AM - Post#2710381
Try a factory type replacement starter for a 95 LT1 car, F-body or full size.
bluesfella
Loc: Tallahassee FL
10-12-17 08:14 AM - Post#2710626
In response to 65_Impala
I asked Blueprint Engines (the ones I bought the motor from), and this was their response:
"I hear this a lot from customers using aftermarket mini starters. For a 153 tooth sized flexplate, I would suggest using a starter from the 1986 – 1992 Corvettes. They were a small starter and those Vettes all had 153 tooth flexplates. GM made thousands and thousands of these and they worked. I put a link to Napa’s website below, but I am sure all the major parts store chains carry them."
Here's the link
BigDogSS
Loc: SoCal
Reg: 12-21-01
10-12-17 09:49 AM - Post#2710636
X2 on the 1995 LT1 starter from a Caprice or Camaro. You can buy a NEW ACDelco starter from Rock Auto for around $100.
models916
Loc: Addison, IL
Reg: 05-28-10
10-13-17 05:10 AM - Post#2710712
In response to BigDogSS
That starter is dual bolt pattern. Are you in the correct holes to mount it?
bluesfella
Loc: Tallahassee FL
10-16-17 12:12 PM - Post#2711020
In response to models916
Yep. The other holes would have it way too far out.
