Username Post: Show you v8 s10.        (Topic#347562)
Boshears
Reg: 03-06-17
10-08-17 09:40 AM - Post#2710133
I'm in the process of doing a swap on one of my s10's. Need some ideas. Dropping a 355 with a th350 in.
Senior Chevytalk Moderator
10-08-17 10:12 AM - Post#2710136
    In response to Boshears
What year truck? Iron block or LS? LS engines are plentiful. With a little work, they can be converted to a carburetor. You can do all the FI and trans but carb is different. I would do carb just to add a dual snorkel intake.
An LS 4.8 and 5.3 will make nice HP with only little modifications.
SleeperSS
Loc: Spanaway, Wa
Reg: 10-17-04
10-08-17 12:17 PM - Post#2710152
355 would be a non LS engine. I would not go with a TH 350.A 700 R4 would be an excellent choice since it's a 4sp. I'm going to guess it's a 1st gen S10, which would make it easier to convert to a carb. If it's a 2nd gen, the problems will only go up from there using a carb and TH 350 . I would go to www.V8S10.org and read ALL of the stickies. The pics are most likely all gone thanks to the crooks at photobucket, but the info is still good.
U.S.C.G. "So others may live"
'96 S-10 SS
'02 BlaZeR2
Boshears
Reg: 03-06-17
10-09-17 02:30 AM - Post#2710239
It's a 91 short deb.
toro455
toro455
Loc: Western NY
Reg: 06-15-02
01-01-18 11:18 AM - Post#2719677
    In response to SleeperSS
Wow there's a lot of activity on that V8S10 site. Good to see interest because maybe it means places will continue to make replacement parts.
I bought mine because I wanted a RWD manual transmission, full frame and needed the utility of a small pick-up. I guess getting off topic but I thought about getting a replacement this past year and my conclusion was there are zero offerings for 6cyl manual in a "small" truck. I included mid-size because nobody makes a small truck anymore.
Execution time: 0.261 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:25 PM
