Username Post: Mirror Installation        (Topic#347546)
jacketman
Reg: 03-03-03
10-07-17 11:22 AM - Post#2710053
My recently purchased "52 had a stock type exterior mirror on the left side that mounts on the cowl.
I purchased a repo stock type mirror for the right side with the same type mount but with the curved arm. Seemed like a simple proposition; use the rubber gasket to mark the holes and drill them. Not quite. Can't drill through the cowl. Drill easily went through the top layer of sheet metal, but no further. Even tried a high speed metal drill. No go.
A previous owner was able to drill through the left side in the same cowl location. Any suggestions on drilling through?
bobschevytrucks.com Ecklers Chevy Trucks
GregH
GregH
Reg: 01-25-04
10-07-17 12:00 PM - Post#2710054
    In response to jacketman
Hate to say it but I bet you drilled in the wrong place. If you look from the inside of the cab, you will see the holes in the inner structure that marked where the mirror went. May have to remove glovebox.. I don't remember for sure the best way to see them.
jacketman
Reg: 03-03-03
10-07-17 03:40 PM - Post#2710080
    In response to GregH
Thanks, Greg. I looked on the inside and there is only one hole on the inner panel. A second hole would still need to be drilled from either the inside or outside.
jacketman
Reg: 03-03-03
10-07-17 03:41 PM - Post#2710081
Also, the hole on the inner panel is much bigger than the holes on the mirror bracket.
GregH
GregH
Reg: 01-25-04
10-07-17 06:18 PM - Post#2710086
Mine is a 54 and this was the best picture I could find right off, but you can kind of see the holes in the inner frame. PM an e-mail address if you want. I can't figure out how to insert an image.
Mick53
Platinum Supporting Member
Mick53
Loc: Northern Indiana
Reg: 04-02-16
10-10-17 06:31 AM - Post#2710384
You might try a cobalt drill bit. That's what we use on stainless steel. You can get them at most hardware stores. Just a little bit more money than steel.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
10-16-17 06:48 PM - Post#2711063
    In response to Mick53
Also cutting fluid and slower speeds to keep the heat down and maintain the drill sharpness.
Cheers kiwi
Execution time: 0.399 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:02 PM
