LMC Truck
Username Post: Horrible satellite radio reception        (Topic#347511)
Miami Son
Loc: God's waiting room
Reg: 08-03-17
10-05-17 10:54 AM - Post#2709840
This is my 3rd new vehicle with satellite radio and I have never seen such poor reception. My 2012 Ram and 2015 Jeep both rarely lost reception unless it was storming really bad or I was under something. My 2017 'Burb loses reception all the time and in broad daylight with no obstructions. Not just a little blip, mind you, but complete signal loss of 10-60 seconds. Anyone else see this kind of signal loss on their 'Burb?
LMC Trucks
10-05-17 11:24 AM - Post#2709844
    In response to Miami Son
I couldn't tell your location, but from what you explained about your previous systems working, it sure sounds like a defective radio or antenna system.
rockfangd
Loc: Utica ny
Reg: 04-13-10
10-05-17 06:06 PM - Post#2709888
I agree.
I have 2 satellite systems and both are fine.
You either have a bad antenna, bad antenna wire, or loose connection.
Check your antenna connection to be sure it is seated well.
With my experience with the satellite radios is that the antenna cable must be perfect. If the shielding is damaged it will cut out.
Sometimes the copper center will break and the only way to know is to replace the cable.
It is a solid wire shielded by plastic inside the cable
Old School GM fan FOREVER
Miami Son
Reg: 08-03-17
10-06-17 09:23 AM - Post#2709929
    In response to rockfangd
On a brand new truck? Crap!
Lorence
Reg: 05-23-17
10-06-17 11:10 AM - Post#2709938
Poor receiver ground is another possibility. Let the dealer check it out first. It may be a problem GM is already aware of.
Miami Son
Reg: 08-03-17
11-21-17 10:59 AM - Post#2715206
    In response to Lorence
Just thought I'd update this post with some info. Truck was into the dealer this morning for its 1st oil change. I mentioned to the service advisor that I was having issues with satellite radio reception and if maybe the tech could check it out. The SA came back a half hour later to tell me that they had found a service bulletin on the vehicle for antenna leaks and that they were going to replace the antenna for free. He said they found some water in there and that it could be shorting the antenna out and causing my reception issues. If you are having similar issues I suggest a visit to your dealer and ask them about this service bulletin. I'll know if it fixed the problem later this week when I hit the interstate.
rockfangd
Loc: Utica ny
Reg: 04-13-10
11-23-17 06:55 PM - Post#2715528
there you go.
The antennas are very finicky if they are compromised.
Should be fine once repaired
elcamino
elcamino
Reg: 03-30-00
11-27-17 07:41 AM - Post#2715911
When they replaced mine last summer they said it only affected models with body colored roof antenna.
#15155: Customer Satisfaction Program – Loss of GPS, OnStar and XM Antenna Functions – (Aug 7, 2015)
Subject: 15155 – Loss of GPS, OnStar and XM Antenna Functions
Models: 2015 Cadillac Escalade, Escalade ESV
2015 Chevrolet Silverado Crew Cab, Suburban, Tahoe
2015 GMC Sierra Crew Cab, Yukon, Yukon XL
*****THIS PROGRAM IS IN EFFECT UNTIL AUGUST 24, 2017.*****
Condition
Certain 2015 model year Cadillac Escalade, Cadillac Escalade ESV, Chevrolet Silverado Crew Cab, Chevrolet Suburban, Chevrolet Tahoe, GMC Sierra Crew Cab, GMC Yukon, and GMC Yukon XL vehicles may have a condition that can allow water to leak into the vehicle’s roof-mounted antenna. This condition could prevent the vehicle’s OnStar system from accurately determining the vehicle’s location; disable the vehicle’s compass, navigation, and XM radio systems; illuminate the vehicle’s red OnStar LED indicator; and allow water into the interior passenger compartment.
Dealers are to replace the OnStar antenna.
Note: Use the vehicle identification number (VIN) and the GM Electronic Parts Catalog (EPC) to determine which High Frequency Antenna to order.
2017 GMC Sierra Denali Ultimate 6.2L(420hp)/8-sp
2016 Polaris RZR 900 EPS
Miami Son
Reg: 08-03-17
11-28-17 03:44 PM - Post#2716155
    In response to elcamino
UPDATE: the antenna fix did not solve my reception issues as I lose signal in the same places as before. Has to be an issue with the vehicle itself as my 2 previous vehicles with Sirius had no issues with signal loss and I am still living near and driving the same streets. It is so bad that I will not be renewing my Sirius when it expires.
Edited by Miami Son on 11-28-17 03:44 PM. Reason for edit: No reason given.
rockfangd
Loc: Utica ny
Reg: 04-13-10
11-28-17 07:23 PM - Post#2716199
hmm.
Is there a mountain or something high in the area?
Mine goes out going through the hills in Vermont but I dont mind as the sightseeing is worth it
Miami Son
Reg: 08-03-17
11-29-17 12:02 PM - Post#2716265
  • rockfangd Said:
hmm.
Mountain? Not here in S. Florida.
rockfangd
Loc: Utica ny
Reg: 04-13-10
11-29-17 06:48 PM - Post#2716324
lol
LMC Trucks
Execution time: 0.267 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:22 PM
