LMC Truck
Username Post: truck stales at low speeds        (Topic#347508)
teddybear15
teddybear15
Loc: Thatcher Az
Reg: 08-25-15
10-05-17 06:04 AM - Post#2709815
got a 1988 Chevy S 10 had a 4.3 swap to a 1988 5.7
at 30 mph driving it thru the neighborhood or even the first start of the day just idling it wants to die the comes back to life. there are no codes.. what might be the problem here.
1988 chevy S 10 4x4 had a 4.3 swap to a 1988 chevy 5.7 engine came out of a K 1500 truck 4x4
LMC Trucks
Senior Chevytalk Moderator
10-05-17 06:34 AM - Post#2709821
    In response to teddybear15
Does idle ramp up then down? What is the FI system?
Temp low/high revs are good indicators of a leaking pressure regulator. A loose vacuum line. Bad timing. Dead stop on a throttle sensor.
teddybear15
teddybear15
Loc: Thatcher Az
Reg: 08-25-15
10-05-17 07:39 AM - Post#2709827
Does idle ramp up then down no
it has tbi
temp it is running about 190
10-05-17 01:45 PM - Post#2709857
I meant temporary high/low RPM swings. Dead spot on the throttle position sensor.
LMC Trucks
Execution time: 0.221 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:03 AM
