Username Post: Call for ideas - removing body rust (entire body) on panel truck        (Topic#347428)
a33nitsuj
Reg: 09-30-17
09-30-17 08:19 PM - Post#2709333
Hello,
I'm hoping to get some alternative ideas to removing body rust from a 54 chevy panel truck. This was a barn find; the entire body is covered with rust. Some spots are thinly covered whereas some spots have been eaten through. Is there any method available, with the exception of snadblasting or bead blasting, that is effective against removing or chemically changing this much rust effectively? To be clear, i want an alternative method to bead or sand blasting for the purpose of removing rust. Any ideas?
bobschevytrucks.com Ecklers Chevy Trucks
Jalapeno
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
10-18-17 06:35 PM - Post#2711297
    In response to a33nitsuj
Justin, soda blasting might be the best alternative for your situation. Baking soda is the media.
Jalapeno
BAM55
BAM55
Loc: Inglewood, CA
Reg: 02-22-11
10-20-17 12:36 PM - Post#2711500
    In response to Jalapeno
Baking soda is great at removing paint but will only remove light rust. There other adbrasives that are the best for removing rust. Other than blasting your other option is machically stripping the rust with a rust stripping wheels or chemicals. You can get the vehicle chemically dipped (not an option where I live) that would work or you can try removing it yourself. I done that with phosphoric acid mixed with 50% water. You can get it at home depot or Lowes.
Here is a pic of a hood I stripped machanically.
Here is a frame I derusted with it.
Question? Why don't you want to get the body blasted? Here is a pic of how my cab came back after media blasting. Blasted with the right media
My Chevy Truck Project
Edited by BAM55 on 10-20-17 12:39 PM. Reason for edit: No reason given.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
10-23-17 05:04 AM - Post#2711784
    In response to BAM55
Hi Guys, large flat panel vans are very sensitive to media blasting causing panel distortion. A full body dip does not involve blasting, however it does require a thorough follow up rinse and then a spray with a phosphoric acid based sealer.
It should remove all old paint and all rust. Sometimes what you get back can be heart braking as what you thought was mild rust turns out to be like Swiss cheese and was full of filler.
Cheers Kiwi
Execution time: 0.369 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:27 PM
