Can anybody help me.
I had a 2002 S10 rear brake line blow out. Replaced all brake lines to back. New calipers and rotors in front and new pads all around. Bled out brakes but pedal still goes to floor. I did test master cylinder by plugging ports and that's good.
If I remove lines from abs modulator and straight to master cylinder brakes a little sponge but working (prob a little more bleeding). But back on abs modulator straight to the floor.
Could that be leaking or can I bleed out modulator manifold if air trap in there? Please any thoughts. Before dumping more money into it.
