Username Post: Initial RPM??        (Topic#347394)
farm rat
Reg: 09-13-16
09-28-17 01:27 PM - Post#2709137
I have heard all kinds of opinions but I value the expertise here.
What should I set my at park rpm's at?
Right now I am around 850-900. Any lower and it feels like it wants to die when I put it in gear.
This is the cam I am running
https://www.summitracing.com/parts/sum-k1301
I am running a Carter performance 750 AFB
Edited by farm rat on 09-28-17 01:28 PM. Reason for edit: No reason given.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
09-28-17 03:04 PM - Post#2709142
    In response to farm rat
850 rpm-900 rpm should be fine, idling in gear
Junkyardwarrior
Loc: Yuma AZ
Reg: 02-25-15
09-28-17 03:08 PM - Post#2709143
Your park rpm doesn't really matter unless there is something wrong with the air fuel mix or timing and the drop from park to drive is ridiculous. When you go into gear you should have about a 100-300 RPM drop depending on cam and converter and all that other good stuff. Your idle RPM needs to be set in gear. If you need to idle at 750 per cam instructions or if you're going off the sticker under the hood, set the idle to 750 in gear. Past that, in park it doesn't matter.
Execution time: 0.197 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:25 AM
