Username Post: 1939 Resto Mod        (Topic#347362)
Buddy Mewbourne
Loc: Talladega, Alabama
Reg: 03-04-04
09-26-17 04:31 PM - Post#2708951
Putting a 350 cu in motor with 700r trans in my 1939 2 door. I Am going without the computer stuff.
All I have read about modifying the 700r is so confusing. I installed the lock up or maybe lock down kit. It has solenoid and 2 prong pressure switch inside. Will some trans expert explain in simple terms what else I need. Some have said I need a brake switch and a low pressure switch. Others said I need nothing. Please help.
Second Bridge Garage
09-26-17 06:06 PM - Post#2708965
    In response to Buddy Mewbourne
Might try your question down in the High Performance forum. I am sure we do have some experts here on this forum, good luck with your answer.
09-26-17 06:41 PM - Post#2708973
If you mean the torque convertor lock up control, there are several types available. Monster transmissions in Fla. has a fairly simple kit that can installed, give them a call.
Execution time: 0.232 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:43 AM
