Username Post: 1947 Fleetmaster new project        (Topic#347318)
Sauceman
Sauceman
Loc: Napanee, Ontario
Reg: 08-29-15
09-24-17 06:19 PM - Post#2708728
Just picked this one up, not going to paint it, just get it running and re upholster the interior.
It doesn't have the original 216, but there is a 261 that came with it.
cheers
Good judgement comes from experience, and often experience comes from bad judgement.
Yugoslavia '94' , Israel/Syria '99 , Bosnia '02 , Afghanistan '08-'09
Rustchips
Rustchips
Loc: DFW Texas
Reg: 02-24-05
09-25-17 05:01 AM - Post#2708751
    In response to Sauceman
Looks like a good project.
Cleon
1928 Chevy Coupe
1955 Chevy Bel Air HTP
1970 El Camino
1990 F##d Mustang Convertible
09-25-17 09:00 AM - Post#2708769
Does it still have the torque tube rear end?
261 is a good find.
Sauceman
Sauceman
Reg: 08-29-15
09-25-17 04:21 PM - Post#2708832
Thanks, yes it has the original torque tube. I have a newer 3 speed manual from a 64 Impala that I plan on installing to get rid of the torque tube. Hopefully it will be a straight forward swap.
cheers
lofat46
2nd Year Silver Supporting Member
lofat46
Loc: Bloomingdale, IL
Reg: 08-12-13
09-26-17 06:40 AM - Post#2708883
To complete your conversion find a '55-'57 Chevy rear end. To center the wheels in the rear fender openings you'll have to drill spring locating holes in the rear end's mounting pads 1-3/4 inches towards the front. Use the '55-7 U-bolts and lower shock plates and you should be good to go. The stock springs are narrower than the '55-7 but it will work. That's what I did on my '46 years ago before I switched to the wider leaf springs from Chassis Engineering. In fact if I remember correctly, a '57 Chevy 4-door driveshaft fit right in.
1946 Chevy Fleetmaster 4-door Street Rod
Sauceman
Sauceman
Reg: 08-29-15
09-28-17 03:53 AM - Post#2709080
    In response to lofat46
Awesome, thanks for the info!
I will concentrate on getting it on the road first then tackle these mods as time permits.
cheers
autorepairguy
Reg: 04-10-16
10-27-17 11:59 AM - Post#2712371
Wow! Pretty clean for an Alberta car!Nice.
67Spirit
67Spirit
Loc: Washington NC
Reg: 03-03-14
02-16-18 07:03 AM - Post#2724560
    In response to autorepairguy
Hope you can show some updates soon, Nice project as it is!
Tim in NC
49 Styleline Deluxe, w/'54 235 I-6 3sp man
67 Mustang
84 Fiat Spider 2000
96 Chevrolet Caprice Classic (DD)
00 Chev Z-71
04 Sport Trac
http://s1342.photobucket.com/user/mrmach170/librar ...
Execution time: 0.4 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:43 AM
