Username Post: Are 65 and 66 convertible frames interchangeable        (Topic#347273)
PMBell357
Reg: 03-24-16
09-21-17 08:53 PM - Post#2708468
My frame has rust.....need alternatives? OR can the frame be repaired or is it worth repairing?
"14th Year" Platinum Supporting Member & Moderator
09-22-17 12:24 PM - Post#2708535
    In response to PMBell357
65 and 66 convertible frames are interchangeable. 67 frames use different rear control arms due to a change in the rear cabin dimensions.
The frame in my 65 SS coupe broke near the driver side crossmember mount. It was repaired by welding a piece of large angle iron material trimmed to fit inside the frame, then welding a "cover" over the removed frame material created to get the angle inside the frame. Then the whole inside of the frame was coated (flooded) with single stage urethane semi-gloss paint.
You haven't given the severity of your frame's damage so it's harder to give you a recommendation on what to do.
One thing to consider is that your VIN number is stamped on the frame if that makes a difference to you.
PMBell357
Reg: 03-24-16
10-03-17 06:11 PM - Post#2709696
    In response to 427SS65
Thx Tom!
10-03-17 07:14 PM - Post#2709704
bigbowtielover
bigbowtielover
Loc: Surrey British Columbia
Reg: 09-01-13
11-10-17 09:50 PM - Post#2713976
There are minor differences in '65-'66 frames. The rear cross member behind bumper has different bolt spacing so holes will need to be modified. Front swaybar mounts are different too. A '67 frame will fit and has better steering. Some mods required though. I have used '67 frames under '65-'66 cars before and am currently doing a '66 wagon frame swap with a '67 frame.
Execution time: 0.345 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:59 PM
