Username Post: PCV???        (Topic#347265)
farm rat
Reg: 09-13-16
09-21-17 09:37 AM - Post#2708373
Is it better to run the PCV off the carb or the intake?
IgnitionMan
Reg: 04-15-05
09-21-17 10:02 AM - Post#2708376
    In response to farm rat
Primary end of carb.
farm rat
Reg: 09-13-16
09-21-17 11:34 AM - Post#2708388
    In response to IgnitionMan
Thanks buddy.
Now, how about the brake booster? Carb or intake?
09-21-17 12:13 PM - Post#2708396
Intake, you need larger volume for the booster.
farm rat
Reg: 09-13-16
09-21-17 02:58 PM - Post#2708416
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
10-01-17 10:05 PM - Post#2709450
Hi Farm Rat, if your carb has a spigot for PCV then that implies it was designed, (jetted) to run the extra air. So definitely use that carb point.
Also see if you can find out what value or part number PCV valve matches that carb/car.
Brake boost should be off the manifold, or a pump system. When you dive to the brake pedal you will have closed the throttle and the manifold signal begins to rise imediately to assist the booster.
If that is not enough boost then you need auxiliary supplies and/or tanks. Small turbo diesel pick ups with car style brakes use a booster pump on the alternator.
They tend to max out at 30"Hg at best but routinely produce in the 20-25"Hg range which is usually more than enough. The down side is they need a constant oil feed and sump return like a turbo.
My experience is these unit really last and the local auto electrician gives me new units when he replaces complete alternators.
Plan B is to use an electric Vacuum pump and tank system. There are kits in the aftermarket but in my view they are over priced. You could look for an OE unit you can use, but it will need to be big enough.
Be aware it will make noise and vibrate, it will need a relay.
Do Not make the mistake of getting an OE unit that is not for brakes, as some VW ,AUDI,etc use these pumps for the climate control system.
Cheers Kiwi
Edited by Bel Air kiwi on 10-01-17 10:11 PM. Reason for edit: No reason given.
farm rat
Reg: 09-13-16
10-02-17 12:19 PM - Post#2709504
    In response to Bel Air kiwi
How would you match a PCV to your carb?
IgnitionMan
Reg: 04-15-05
10-02-17 01:35 PM - Post#2709512
It would be matched to the vacuum level the engine produces, not the carb.
A valve for a 390 horsepower 427 big block is completely different on spring tension, to match the higher vacuum, than one for a 425 horsepower 427 big block that has significantly less operating vacuum because the intake valve closes later on the higher horsepower engine, lowering both Dynamic Compression Ratio, and idle/lower RPM vacuum, from increased mixture reversion up the intake ports.
What idle vacuum level does the engine produce now?
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
10-09-17 08:19 AM - Post#2710276
To elaborate on Dave's comments, I once bought several PCV valves from Rock Auto (at very low prices), all for different Chevy engines from the 60s-70s. Thought I could test them with a Mityvac, but couldn't generate enough air volume.
So then I installed each one on a warmed-up engine to see which one let the engine make the most vacuum. The difference among the valves at idle was no more than 1" hg, but I chose the one that consistently made made the most vacuum. As I recall, the engine had been making around 16" vacuum at idle, and it jumped to 17" with the new valve. Could be the old one was designed for an engine making high vacuum, and started opening a little too soon for my engine. I suspect that a 425hp/427 valve wouldn't start opening until something lower than 12"-14".
Execution time: 0.255 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:09 PM
