Username Post: New body panels        (Topic#347212)
Mick53
Platinum Supporting Member
Mick53
Loc: Northern Indiana
Reg: 04-02-16
09-19-17 04:54 AM - Post#2708104
I'm restoring a 53 chevy pickup. I'm replacing a lot of the body panels including the entire bed. It will have a show paint job. How should I prep the new panels to keep them from rusting until I get them to the painter? I live in northern Indiana. It will be kept in the shop but we have very high humidity.
09-21-17 07:31 PM - Post#2708455
    In response to Mick53
If the parts are in Electro Deposit Primer (EDP) they should be fine until you are ready to scuff them for sealer and paint.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
09-22-17 02:53 PM - Post#2708546
    In response to wagonman100
a good coat of extra paint , carefully applied and allowed to dry to seal the surface will certainly add to the rust protection potential but youll need to be careful to use a paint that will both seal and protect the parts from moisture AND not cause you problems later when you need to weld or paint that parts surface, so I would do some research before selecting any paint and I damn sure would not select any wax based protective spray.
you might be better off placing the parts in large plastic bags sealed with duct tape along with several sheets of news paper as the news paper will tend to trap and hold minor amounts of air born moisture
Mick53
Mick53
Reg: 04-02-16
09-25-17 10:16 AM - Post#2708782
These are just bare steel
Mick53
Mick53
Reg: 04-02-16
09-25-17 10:18 AM - Post#2708784
these are just bare steel
Mick53
Mick53
Reg: 04-02-16
09-25-17 10:18 AM - Post#2708785
    In response to grumpyvette
Thank you.
09-29-17 03:16 PM - Post#2709232
If they are bare you can spray them with an etch primer and then a good 2k or epoxy primer. As long as they only see atmospheric moisture, they should be fine.
Mick53
Mick53
Reg: 04-02-16
09-30-17 05:59 PM - Post#2709317
Thanks Jay
Execution time: 0.228 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:28 PM
