Username Post: 3 speed manual with overdrive        (Topic#347191)
Chevy_Stepside
Chevy_Stepside
Loc: San Francisco, Ca, USA
Reg: 07-08-02
09-17-17 09:47 PM - Post#2707969
I am going to search but I was wondering if anyone knew how to hook up the solenoids of maybe you know of some good info on the net. I have 3 of these transmissions right now sitting in my garage. I want to put one in my original truck as my tranny is about to blow up.
"A man and his truck, It's a beautiful thing"
The tour is on again. May 1st 2011. $5 I ride 100 miles. http://main.diabetes.org/site/TR?pg=personal&a mp;f...
09-18-17 12:01 PM - Post#2708041
    In response to Chevy_Stepside
Here is the stock B-W wiring diagram:
http://www.hotrodders.com/forum/attachment.php?att...
However, unless you are doing a show quality resto and are willing to pay for some rather scarce and pricey parts, there are much simpler and less expensive ways to get the job done. I can't send you a diagram of the setup I am using, but will be glad to talk with you about it. If you would like to give me a call, I am sending a PM with my phone no.
1967427c
Loc: Mississippi
Reg: 02-27-15
10-08-17 09:29 PM - Post#2710226
One of the best things I did in the restoration of my 1963 C10 was the installation of a manual OD transmission. I wanted to keep the truck as close to stock (manual column shift) but do something about highway drivability. I love it. 65 - 70 MPH at 2000 RPM.
My OD came out of a car and I used the side plate off my original 3 speed as the shift rods for the transmission were longer on the truck tranny than the car. This allowed for body/frame clearance for the rods going to shift column.
If you have not already talked to Ray, you should. He was great help when I did the installation. There are several post on this subject.
Chevy_Stepside
Chevy_Stepside
Reg: 07-08-02
10-09-17 09:42 PM - Post#2710369
    In response to 1967427c
I haven't had the time to install the trans yet.
Edited by Chevy_Stepside on 10-09-17 09:43 PM. Reason for edit: No reason given.
Chevy_Stepside
Chevy_Stepside
Reg: 07-08-02
11-21-17 07:04 PM - Post#2715250
I got the trans in today and will be dropping off the driveshaft tomorrow to get shortened.
hilandr451
hilandr451
Loc: Anna Texas
Reg: 01-02-02
11-22-17 06:02 AM - Post#2715296
Ed down at Fairfield Transmission next to the PickNPull you and I used to go to, knows all about that. He was going to set mine up when I upgraded to an EFI system. He did an excellent job building that 700r4 trans I bought from Mikey. Then had no qualms about adjusting it for free after I installed it 2 YEARS LATER!
-The Hilander.
Silver 2017 Silverado 1500 double cab 2WD 5.3L
"Rattle can primer red" 1966 C20 Custom Camper 5.7L, 700 R4 trans 410 diff. front disc, p/s
Project Pics
Chevy_Stepside
Chevy_Stepside
Reg: 07-08-02
11-22-17 07:48 AM - Post#2715320
    In response to hilandr451
I'm not using a 700R4. It is a 3 speed Saginaw so I can keep my 3 on the tree. The unit I put it had been gone through so it is pretty much rebuilt. If it is trash I have two more to try out.
Chevy_Stepside
Chevy_Stepside
Reg: 07-08-02
11-28-17 04:21 PM - Post#2716168
It is in and working. Now for a nice freeway ride.
Chevy_Stepside
Chevy_Stepside
Reg: 07-08-02
12-01-17 12:52 PM - Post#2716561
Was cruising on the freeway today at 75MPH. Felt the same as 60 without overdrive. I love it as I knew I would.
12-01-17 04:21 PM - Post#2716581
Yes, dealers just plain screwed up by not having a demo car or truck with OD. I know a test drive would have convinced a lot of potential buyers.
1967427c
Loc: Mississippi
Reg: 02-27-15
12-04-17 08:30 PM - Post#2716911
It really is a great change. I love mine and makes trips so much more pleasurable.
I don't know if has been previously mentioned but my transmission has two "filler" points. One on the front section and one for rear. I made sure transmission fluid was flush with both.
Chevy_Stepside
Chevy_Stepside
Reg: 07-08-02
12-04-17 09:18 PM - Post#2716916
I only noticed one on mine. Maybe I should take another look. I have two more that will be up for sale soon.
Execution time: 0.261 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:04 AM
