Username Post: Brakes still spongy after replacing hardware        (Topic#347120)
Adam63impala
Adam63impala
Loc: From Memphis to Florida
Reg: 12-01-15
09-13-17 12:10 PM - Post#2707568
Okay so me and a coworker of mine replaced all 4 wheel cylinders, pads and springs , bled brakes twice and I also bled the MC . Drove In reverse a few times and slammed on brakes . Still didn't help . Still spongy . . They felt alot tighter before the change and would screech tires to a stop . . What else can I try ? Maybe adjust all 4 star wheels a little more ? Thank guys
gkralik3645
gkralik3645
Loc: omaha
Reg: 12-05-13
09-13-17 03:04 PM - Post#2707580
    In response to Adam63impala
Did you adjust your brakes before you did the backing up and hitting the brake pedal? You must.
George
Adam63impala
Adam63impala
Reg: 12-01-15
09-13-17 03:08 PM - Post#2707582
    In response to gkralik3645
He adjusted them to where they dragged just a little .. should I make them a little tighter ? I just don't want to go too tight ..
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
09-13-17 03:22 PM - Post#2707584
Just give the star wheel's a couple more clicks see if it helps . I had my fronts off a bazillion times to get them to quit pulling to one side.
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327
Adam63impala
Adam63impala
Reg: 12-01-15
09-13-17 03:24 PM - Post#2707585
    In response to 69_BOWTIE
OK I will try that , just the fronts ?
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
09-13-17 03:35 PM - Post#2707587
My experience is that the rear wheel adjustment has more affect on the brake pedal than the front.
I install self adjusting brakes on all 4 wheels on my 62's (that did not come with them from the factory.)
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
62 Imp CV SS 327/300HP 700R4
62 ImpHT SS 409/482 stroker 4 spd
62 Imp SS 409 - 5 spd Convertible under frameoff
Web http://paulstensland.com/
Adam63impala
Adam63impala
Reg: 12-01-15
09-13-17 04:20 PM - Post#2707593
    In response to pvs409
Okay cool I will try the rear first . Also I thought my 63 had self adjusting ..maybe not
threeimpalas
Loc: Central Iowa
Reg: 02-21-02
09-14-17 05:37 PM - Post#2707669
If they're still spongy after adjusting the shoes, then you likely still have air in the system.
'58-62s and 348/409s
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
09-14-17 06:32 PM - Post#2707678
Spongy is ALWAYS air in the system. Always.
My two pennies after working on these cars all of my driving life. That started when your car was new.
IF you're gonna be a bear..........
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
1963er
1963er
Loc: Joppa, Md.
Reg: 12-20-15
09-15-17 04:39 AM - Post#2707710
    In response to beagrizzly
Did you bench bleed the Master Cylinder? That will cause the problem
junky
Loc: Northeast CT
Reg: 06-27-10
09-15-17 07:44 AM - Post#2707722
    In response to 1963er
Ah... Pray tell, how can bench bleeding the master cylinder cause a problem?
55Brodie
55Brodie
Loc: Little River, SC
Reg: 12-26-15
09-15-17 05:13 PM - Post#2707755
Double check you have the brake shoes oriented correctly. When adjusting the drag, do so with the tires/wheels installed. Tighten the star wheels until you can no longer rotate the tire by hand, then back off 7 or 8 clicks.
did you replace the 2 front and 1 rear brake hoses?
rober
rober
Loc: sweden
Reg: 03-13-15
09-16-17 10:16 PM - Post#2707884
i have put in disc brakes in front and Everything is new, master cylinder etc and i did bench bleed the master cylinder but why is that so important?
4dr 57
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
09-17-17 07:36 AM - Post#2707901
Use a syringe to back bleed the MC. Have a second tub of new brake fluid so you don't reuse aireated air.This will make the process much easier as you can bleed the MC on the car.
Use speedy bleeders (Earl's are good) to bleed the lines. You can leave them in place when finished.
When bleeding, start with the wheel cylinder farthest away from the MC 1st. This is usually the right side rear but check this to make sure.
Stanley
Adam63impala
Adam63impala
Reg: 12-01-15
09-22-17 01:44 PM - Post#2708541
    In response to 4dr 57
Just seeing these replies ..for some reason I'm not getting emailed anymore even though it says I'm subscribed to this topic with instant email .
Anyways , I bled my brakes Wednesday , quite a bit of air came out the back pass one . It's alot better now but still not as tight as before ..I'll adjust the star wheels more. Thanks guys
Adam63impala
Adam63impala
Reg: 12-01-15
09-22-17 01:46 PM - Post#2708542
You click the starwheel down a click to tighten the shoes out correct ?
omarine
Loc: San Diego
Reg: 06-29-15
09-25-17 09:37 AM - Post#2708778
yes, so the end of the spoon in your hand travels upwards. I like to do it till I feel / hear slight drag, then I leave it. the book says to then back off some clicks, but I never do. im still running all 4 drums
61 Impala bubbletop, 283, 2bbl Rochester, generator, points and drum brakes- daily driver
'49 Harley Davidson FL - Panhead
Execution time: 0.357 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:16 AM
