Username Post: Applying intake gasket RTV        (Topic#347115)
BigBoreFun
BigBoreFun
Reg: 09-12-17
09-12-17 09:58 PM - Post#2707533
A 1/4 inch bead, or so, should be used to mate the front and rear of the block to the intake. Are there concerns about the RTV breaking off inside the engine?
'62 Impala
'65 C-10
'69 Chevelle
64ausbelair
64ausbelair
Loc: Australia (QLD)
Reg: 10-26-06
09-12-17 11:06 PM - Post#2707535
    In response to BigBoreFun
I suppose the worst that could happen would be it makes its way down into the sump, then what. Maybe get sucked into the oil pump if its small enough and gets through the screen. The pump would make short work of a piece of silicon. Then it would end up in the filter.
If you do a nice even bead on your intake you really shouldn't get any in the engine I guess. I wouldn't be overly concerned myself if I knew a bit went in. I'd keep an eye out for it in oil and filter changes.
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
09-13-17 02:24 AM - Post#2707540
    In response to 64ausbelair
RTV is what should be used and is used on thousands if not millions of our small blocks etc., without the rubber end pieces that come with the intake gaskets by the way.
Member #2194
09-13-17 10:48 AM - Post#2707563
    In response to DonSSDD
I cannot even begin to count the engines I've put together using RTV on the front/back of the intake/block mating surfaces. I stopped using the rubber seals which come in intake gaskets sets over 30yrs ago, and glad I did. After pulling some of them apart, I have NEVER observed any RTV broken loose on the inside.
BigBoreFun
BigBoreFun
Reg: 09-12-17
09-14-17 12:53 AM - Post#2707623
I watched a video on someone using rtv to coat a timing gasket and the reason he had it apart was because the oil screen was plugged with loose silicon and the engine spun a bearing. Got me thinking. Thanks for the feedback gents!
'62 Impala
'65 C-10
'69 Chevelle
models916
Loc: Addison, IL
Reg: 05-28-10
09-14-17 04:28 AM - Post#2707625
If a little is good, a lot must be better.
Petrol
Reg: 08-09-15
09-15-17 05:16 AM - Post#2707712
    In response to models916
The old style rubber gaskets for the ends of the intake were a PITA. A bead of RTV was much more reliable. If the metal surface is clean and free from oil, the RTV will adhere nicely and there's little chance of it failing.
Now, the newer style rubber end gaskets stay in place a bit better than the old ones. Even with those I would place a small dab of RTV at the ends.
RTV works fine but if you use the rubber gaskets the best solution is to use some 3M weather strip adhesive (the super sticky yellow stuff) to glue the rubber gasket to the block a few hours before you put the intake back on. If you don't have the time I suggest using RTV without the rubber gaskets.
popper
Gold Supporting Member
popper
Loc: Midwest
Reg: 01-08-08
09-15-17 06:37 AM - Post#2707720
    In response to Petrol
I have always used RTV for intakes. I always try to apply it across the block in one continuous strip. Remember there is a gap and the gasket that is normally there is approx 1/8" thick so it won't have the tendency to push it all out when torqued down. Where people get into trouble is using too much where you pull the sealed surface down with very little clearance, such as timing chain covers, around intake ports and water pumps. The RTV will push out and then has the ability to clog things up. Just use your best judgement about how it is being used and that you don't always need to just goop it on.
popper
John Lynch
"LIFE IS HARD, IT'S HARDER WHEN YOUR STUPID" John Wayne
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
09-17-17 06:28 PM - Post#2707954
    In response to popper
Execution time: 1.263 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:15 AM
