Username Post: Fuel pump low voltage issue        (Topic#347111)
johnboy3927
Reg: 06-08-16
09-12-17 02:34 PM - Post#2707501
I have a 92 Chevy k1500 that has no power and randomly decides to not start. I am only getting 8.5 volts with the key on and 7 while cranking at the fuel pump. I have checked the power wire from the firewall to the pump for continuity and it was good. Just trying to figure out where to go from here. The fuel pump relay is also new.
Edited by johnboy3927 on 09-12-17 02:36 PM. Reason for edit: No reason given.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
09-12-17 05:28 PM - Post#2707516
    In response to johnboy3927
Grounds! What is the battery voltage.
Jeff
'88 Chevy K3500, aluminum head roller cam 511inĀ³ stroker 10.5:1 compression, 96 NV 4500, 94-98 grille, 305/70-16 (33x12) BF Goodrich KM2s, 91 cluster swap
Execution time: 0.427 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:32 PM
