Username Post: weight of front end?        (Topic#347095)
Jalapeno
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
09-11-17 06:49 PM - Post#2707429
I am trying to get a rough idea of how much weight is on the front suspension of a full size 1950s-1960s Chevy.
By that I mean how much weight is the steering trying overcome? I am picturing a fully assembled car (engine, trans, etc.), with modern radial tires (because they generally have more contact surface area with the ground), at a dead stop.
Where would I look for this kind of information?
TIA.
Jalapeno
09-11-17 06:59 PM - Post#2707430
    In response to Jalapeno
Will this spring chart help? ..... Link to spring data.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
09-12-17 06:37 AM - Post#2707469
Here's some data on a '59:
https://www.gmheritagecenter.com/docs/gm-heritage-...
The first page is blank, scroll down to the 'weights'.
It sounds like you are seeking the 'sprung' weight of the front end. You may need to do some estimating to get there.
09-12-17 03:19 PM - Post#2707499
I have a book, "Chevrolet 55-56 Restoration Guide" that has factory weights for all models for 55-56, including front/rear distribution.
They list "shipping weight", "curb weight", and "loaded weight". Shipping weight is empty weight with all lubricants, but no water or fuel. Curb weight is the same with 33 pounds of coolant and 97 pounds of fuel. Loaded weight is 150 pounds for each passenger.
Example 55 Bel Air 2 door sedan 6 cylinder manual trans
Shipping weight 3155 front 1705 rear 1450
Curb weight 3285 front 1740 rear 1545
Loaded weight 4185 front 2065 rear 2120 (6 passengers)
V8 engine is 30 pounds less all off the the front.
Due to the construction of the book, it would be difficult to copy or scan, but I could give you numbers for a few more models if you want them.
These published numbers seem a little light 200-300 pounds) compared to the real world.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
09-12-17 07:27 PM - Post#2707524
    In response to Rick_L
A 1957 car has approx. 1800 pounds on the front wheels.
A 1959 can be another 100 pounds depending on engine and transmission. A cast iron Power Glide or/and a 348 can add another 100 pounds +.
Edited by Gene_Schneider on 09-12-17 07:33 PM. Reason for edit: No reason given.
greencar
greencar
Loc: New Jersey
Reg: 04-03-03
09-13-17 06:23 PM - Post#2707609
Just had my 55 hardtop weighed on truck scale.
Small block, AC, power steering
Total weight car only 3660
Front axel weight 2020
Rear axel 1640
Jalapeno
Jalapeno
Reg: 04-30-00
09-13-17 07:51 PM - Post#2707614
    In response to greencar
Thanks everybody, this is exactly what I need.
Jalapeno
rod
Loc: kingman,az
Reg: 04-29-00
10-08-17 04:12 PM - Post#2710178
I thought my 56 Nomad drag race car was heavy. this is a fully original car except no radio or heater. full original interior. even iron heads. 30 lb. flywheel, 40 lb bellhousing.
and it weighs 3550 with me in the seat. maybe I am blessed and didnt know it!
my computer program says 51% weight on front axle.
Rod in AZ
Edited by rod on 10-08-17 04:13 PM. Reason for edit: No reason given.
Execution time: 0.33 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:00 AM
