Username Post: '58 dash cluster wiring        (Topic#347092)
papastoyss
Reg: 10-25-13
09-11-17 03:21 PM - Post#2707414
I'm rewiring a 1958 passenger car that has been apart for a long time.The firewall forward harness is gone. Can anyone tell me which terminals on the fuel & temp gauges are power supply and sender?I sure don't want to let the smoke out of the gauges! I have a '57 cluster & they are marked on it but not on the '58.
JayChicago
JayChicago
Loc: Chicago
Reg: 01-03-13
09-11-17 06:44 PM - Post#2707427
    In response to papastoyss
When I re-wired my dash a couple years ago, I labeled almost everything to make it easier to do future troubleshooting.(for me or some future owner) So it was easy for me to check this.
On both temp and fuel gauges:
Power supply goes to the outboard terminal.(furthest away from center of instrument cluster)
Wire going to the sender(s) is on the inboard terminal.(nearer center of cluster)
papastoyss
Reg: 10-25-13
09-12-17 07:39 AM - Post#2707473
    In response to JayChicago
THANK YOU!
Execution time: 0.852 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:18 AM
