Username Post: Loss of power in garage        (Topic#347082)
Charlie57
Charlie57
Loc: Lebanon, Tennessee
Reg: 03-30-08
09-10-17 05:17 PM - Post#2707315
While using the pressure washer in my garage I sprayed my outlet and blew the circuit. After 24 hours the circuit will still not reset. In the breaker box it has the ground fault breaker and there is a GFCI outlet in the circuit.
What do I need to do to get my power back? The breaker has blown before and I just hit the reset button and it resets. Now when I hit the button nothing is happening it does not click or try to reset.
Thanks,
Charlie
"Charlie's 57 Chevy" I made it's very own FaceBook page please visit and "Like"
http://www.facebook.com/pages/Charlies-1957-C hevy/214078481937849
09-10-17 07:16 PM - Post#2707330
    In response to Charlie57
Did you dry the outlet out, that got wet?
Charlie57
Charlie57
Reg: 03-30-08
09-10-17 07:32 PM - Post#2707334
    In response to acardon
Don,
I used a heat gun for about a minute I was not sure how long to hold it on without doing damage.
Charlie
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
09-11-17 07:58 AM - Post#2707373
make 100% sure the powers off by flipping the breaker controlling the outlet disassemble the wet outlet, clean dry flush exposed wires with wd40 replace outlet plug assembly,reconnect the wires too new outlet guts, if that won,t cure it, replace GFI outlet also, total time under 15 minutes per outlet even if your not electrically skilled cost under $15 per outlet
Edited by grumpyvette on 09-11-17 08:28 AM. Reason for edit: No reason given.
monty56
monty56
Reg: 04-26-04
09-11-17 08:01 AM - Post#2707375
    In response to grumpyvette
The GFCI outlet may have gone bad, I lost one in my garage ceiling that ran my fluorescent lights. It would reset then trip immediately upon trying to turn on a light.
Monty
2001 Chevy Suburban 2500
2009 Saturn Vue w/20's
Monty's 56 Truck
Avatar is my Truck
wings59
wings59
Loc: Bakersfield Ca
Reg: 01-30-05
09-11-17 10:03 PM - Post#2707446
If your breaker resets and you have power up to the GFI you can take it out of the system by temporarily puting a good plug in its place, then with power to the complete circuit check for a loose wire or bad connection on the other plugs in the circuit. My bad plugs in the circuit were in rooms not even related to where I was working. Plug tester at HF is about $10.
I am not an electrician, only saying this is how mine was repaired, once about 10 years ago, and 2 in past few years by a qualified electrician. Cost about $75. both times. Well worth it.
Larry
59 Impala Sport Coupe
36 Dodge Street rod..........owned 27 years
65_Impala
Reg: 12-29-02
09-13-17 06:56 AM - Post#2707550
If you have a GFCI breaker you don't need the GFCI outlet.
If you hit the reset on the breaker and nothing happens then the breaker is likely bad.
09-13-17 01:23 PM - Post#2707574
Disconnect the wires from the GFCI outlet. Then try to reset the breaker. If it resets now, you know where the problem is. If it won't reset, disconnect the wire at the breaker and try again. If it resets now, check out EVERYTHING connected to that circuit. If it still won't reset, you can be pretty sure the breaker is bad.
Charlie57
Charlie57
Reg: 03-30-08
09-19-17 07:11 AM - Post#2708111
I'm going to try to repair this tomorrow. The breaker does reset but I have not tested to see if I have power at any of the outlets.
Thanks,
Charlie
Charlie57
Charlie57
Reg: 03-30-08
09-25-17 07:44 PM - Post#2708859
Thanks for everyone's help! After replacing the GFCB outlet everything was good!
Thanks,
Charlie
Execution time: 0.305 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:22 PM
