Username Post: Gas cap vented or closed system        (Topic#347047)
cares
cares
Loc: Minnesota
Reg: 08-24-04
09-08-17 11:19 AM - Post#2707048
On my '66 El Camino is the gas tank vented?
I'm unable to find a vented gas cap. After a 20-30 mile cruise I open the gas cap and there is a loud hissing and it sounds like someone is banging the gas tank.
Any advise? Thanks
'66 El Camino
'16 Vette coupe
'66 HD Sprint
'67 Honda Scrambler
Bobschevelleparts.com
09-08-17 02:57 PM - Post#2707068
    In response to cares
If you have no seperate vent off the tank, the cap must be vented.
larrybrowningmauldin
Loc: New Braunfels,TX
Reg: 08-16-05
09-29-17 12:35 PM - Post#2709225
I had to read your post twice as I thought that I had written it AGAIN. Two years ago, I bought a '68 el Camino with the same unvented gas cap problem. After blowing the membrane in the fuel pump and injecting gasoline into the crankcase, the fuel pump had to be replaced. I solved the "whooshing" problem by drilling 2 small holes in the gas cap to create a vented cap. No problems with pressure build up now. My garage does smell slightly of gas vapors; however, a '55 Chevy in the garage would produce the same aroma. My garage smells like a garage.
jberbrich
Reg: 11-22-17
11-22-17 09:19 AM - Post#2715332
    In response to larrybrowningmauldin
My experience...my '69 Chevelle had a new gas tank installed. The dude didn't uncap the vent tubes. How did I figure this out? I ran out of gas twice, even though the gauge was showing half tank. The suction created such negative pressure that my tank was collapsing, and sticking the gauge at half full. I drilled a small hole in the gas cap and took a compressor to reinflate the tank. Then I uncapped the vent. Then I got divorced and had to sell her. (the car).
Execution time: 0.293 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:06 PM
