Username Post: Sanden upgrade        (Topic#347033)
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
09-07-17 04:29 PM - Post#2706963
My brother bought a 95 2500 Cheyenne. The AC doesn't work. I need to investigate, but I would guess it is the belly leaker compressor. The guy said he charged it and it worked and leaked off a week later.
My brother is short on cash so I thought about helping me and him at the same time. I have a good R4 compressor. I'd like to sell (or give) it to him and upgrade mine to the Sanden. I know it's been discussed on here, but what is the part number for the one that is a direct fit? The best one is a 5 piston if I remember correctly.
Jeff
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
09-08-17 09:08 PM - Post#2707116
    In response to bowtie44s
Not sure if it's a direct fit, but there's actually a seven piston Sanden.
Greg
'00 Explorer XLT 4.0 V6 Auto
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
09-09-17 07:46 PM - Post#2707212
    In response to CowboyTrukr
You probably don't know the part number do you? I remember reading somewhere that the 5 piston was better than the 7. It may have been Vaughn but I haven't seen him on here in a while.
Jeff
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
09-09-17 08:00 PM - Post#2707215
508 comes up with the first search.
Greg
tcndeb
Reg: 04-18-04
09-10-17 08:01 AM - Post#2707259
I thought the 95's came with a Sanden SD7H15 from the factory?
'92 Full Size Blazer
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
09-10-17 08:44 AM - Post#2707265
    In response to tcndeb
Nope. The Harrison R4 was still standard
Greg
tcndeb
Reg: 04-18-04
09-10-17 02:44 PM - Post#2707303
I got the Sanden upgrade from Classic Industries for my Blazer. It comes with all the hoses, o-rings, brackets and a dryer, or whatever they call that thing on the firewall. Did all the work myself except charging. Since my system never crashed, I just wanted to upgrade to 134, I kept my condenser and evaporator and just cleaned them real well with cleaner made for that stuff. I can run 39° at the center vent on recirc, 35° if I valve off my heater core line.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
09-10-17 05:14 PM - Post#2707314
My brother's 95 looks just like the R4 in my 88. 95 was originally R134A. 88 was R12 but has been converted to 134.
Jeff
Senior Chevytalk Moderator
09-11-17 04:41 AM - Post#2707356
I just did the conversion on '95 GMC Jimmy
Use an SD7HD. It bolts right in with a bracket kit. An SD5 is too old. SD7HD are built for R134.
The lower R4 bolt is used with an included spacer in the bracket it. The other side is two single half moon brackets. The front one uses a spacer. I had my 1 year new hoses cut and fitted. Depending on where you get it, you might be able to get the R4 back side to make it bolt on application. I preferred the single hose connections. It made it easier to route around other engine bay parts.
If your brother's system worked for a while then leak, it's the valve stems leaking. I've replaced more of them than compressors. Replace the valve stems and pump it down 45 min. If it holds vac, the system is good to recharge.
09-11-17 04:42 AM - Post#2707357
Attachment: R2.jpg (103.92 KB) 10 View(s)
SD7HD with a 90" belt.
09-11-17 08:01 AM - Post#2707374
Attachment: fullinstall.jpg (115.35 KB) 11 View(s)
SD7HD full installation.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
09-11-17 09:18 AM - Post#2707386
Maybe his is just the valve. I still want to switch mine to Sanden. Did you notice a difference in vent temp? Mine usually blows around 50°. Where did you get your bracket kit?
Jeff
09-11-17 09:29 AM - Post#2707387
My local A/C rebuild shop had it in stock. It was made by an aftermarket supplier. I'll post the part number later. I need a cooking thermometer to stick in the vent. It's colder than the R4. The only part not upgraded was the condenser.
tcndeb
Reg: 04-18-04
09-12-17 05:16 AM - Post#2707461
When I upgraded to the Sanden I was advised to switch out the variable orifice tube for a red Ford orifice tube. I don't know if that was a big deal or not but I was pulling 39 degrees at the vent all summer in Austin, even when it was 100 degrees outside.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
09-12-17 06:47 AM - Post#2707471
I went to 3 parts stores and asked for a red Ford orifice tube and no one had a clue what I was talking about.
Jeff
09-12-17 07:58 AM - Post#2707476
Part Number YG346 should fit. Counter people are only as smart as their computer. No input no output.
When I do my C10 upgrade, I'll install the red one too.
Edited by gchemist on 09-12-17 08:00 AM. Reason for edit: No reason given.
tcndeb
Reg: 04-18-04
09-12-17 10:55 AM - Post#2707485
Right! When I asked the counter guy in Elgin for the red Ford tube the first thing he said was "are you doing the 134 upgrade on your Chevy?" He knew exactly what I was after and why I wanted it.
It's kind of sad that running into a good parts guy is cause for celebration.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
09-12-17 06:23 PM - Post#2707514
There was one at autozone of all places. He had every small block part memorized. He never looked at the computer, he just went back and got it. I haven't seen him for years. I'm sure he went to a much more meaningful job. They should have paid him more than minimum wage. He was the reason I went there along with several of my friends.
Jeff
Edited by bowtie44s on 09-12-17 06:25 PM. Reason for edit: No reason given.
09-13-17 04:56 AM - Post#2707541
A good counter guy is hard to find. I learned about A/C systems from a parts guy who recommended someone that did side jobs. I've watch him do several jobs while helping. Now I have my own vac and gauges to do A/C work myself.
Execution time: 0.357 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:15 AM
