Username Post: 1950 Chevy Styline Dash        (Topic#347029)
Larry E
Loc: Los Angeles
Reg: 09-15-16
09-07-17 08:21 AM - Post#2706919
Hello,
Does anyone have a picture of a 1950 Styline dashboard? Looking for the original colors to paint. Someone told me all skyline dashboards were the same two tone color.
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
09-07-17 09:04 AM - Post#2706925
    In response to Larry E
Hum...all 1950 Deluxe dashes were painted the same two tone colors [excuding the convertible and Belair]. And, all 1950 Special models were painted the same single color.
When I worked in auto body I had mixed each of the Deluxe dash colors in Sikkens base/clear. The upper color began as a Honda color and the lower color started as a VW color....each tweaked to match. I can post those formulas later.
In the photo below, I had repainted the garnish molding while the upper dash color is original. You can see a slight section of the lower dash color in the photo as well.
1951 Fleetline
Larry E
Loc: Los Angeles
Reg: 09-15-16
09-07-17 12:43 PM - Post#2706946
    In response to RAM_51
RAM,
Do you happen to know the names of those colors ?
Hopefully I can have my paint find those paints.
RAM_51
RAM_51
Reg: 12-28-02
09-07-17 01:56 PM - Post#2706955
This is about the best I can do as far as codes go. The upper dash color is Titan Gray Poly, and the lower dash color is Silver Gray. The chart below provides a DITZLER code that supposedly will bring you close to the proper color. I've never used this chart or explored these codes to see exactly how close they come. They will probably still need tweaking to be "spot on" evidenced by the notes at the far right. A PPG dealer should be able to help you with the codes provided here. I have the Dupont codes for these two colors as well, but now-a-days a Dupont code is almost useless. The blue, green, and red are for the upper dash color of the convertible.
1951 Fleetline
Larry E
Loc: Los Angeles
Reg: 09-15-16
09-07-17 02:08 PM - Post#2706958
Thanks, Appreciate your help.
RAM_51
RAM_51
Reg: 12-28-02
09-08-17 01:36 AM - Post#2706988
For S&Gs, I decided to research and scan the two color chips for the two grays referenced in the above chart. Of course a computer scanner and monitor will not do justice to these chips. What would be needed to make an appropriate match are numerous spray outs observed in sunlight or other appropriate light source.
Attachment: 1950_DeLuxe_Upper_Dash_Color.jpeg (56.92 KB) 6 View(s)
1950 DeLuxe Upper Dash Color
Attachment: 1950_DeLuxe_Lower_Dash_Color.jpeg (54.45 KB) 8 View(s)
1950 DeLuxe Lower Dash Color
1951 Fleetline
RAM_51
RAM_51
Reg: 12-28-02
09-08-17 05:52 AM - Post#2706999
And these are scans my Sikkens spray-outs: Interestingly, and I never noticed it until now...the notes call for the upper dash color to be darker...which mine is...and for the lower color to be redder...which mine also is.
Attachment: 1959_DeLuxe_Upper_Dash_Color_Sikkens.jpeg (136.33 KB) 8 View(s)
Upper
Attachment: 1950_DeLuxe_Lower_Dash_Sikkens.jpeg (32.18 KB) 7 View(s)
Lower
1951 Fleetline
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
09-08-17 04:51 PM - Post#2707092
Hey Larry
Here's a pic of my '50 Styleline DeLuxe dash. Original paint as far as I can tell.
Good luck.
Attachment: IMAG1371-20170111-093356.jpg (1.53 MB) 6 View(s)
Dean50
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
09-08-17 06:22 PM - Post#2707108
This is a copy from VCCAChat from a few years ago from stefakicoupe
He was kind enough to send the exact formula to whoever asked for it and I have it somewhere. I think I posted here at one time. I'll look around for it.
"I am pretty sure i have the correct paint formulas for a 50 dash,took my rear armrest and glove box door to PPG they shot a pic of both they came up with codes for the colors. we dabbed a spot on both the parts let it dry and they were both pretty close to dead on.am going to paint the top part of dash tuesday. will let all know how it comes out it is not a honda nor volkswagen color as previous post has listed.i have the formulas for both.the colors are = OEM CODE 930404 MERCEDES STEINGRAU FOR THE GRAY (added black after intial mix)AND OEM CODE 919826 KIA TEAL GREEN,NEW GREEN FOR THE DASH NO MODEL YEARS ON EITHER PAINTS =but as from experience not all paint suppliers sometime mix paint the same way.if anybody is interested in a copy of the way it was exactly mixed for me"
Dean50
Mike JW
Mike JW
Loc: Arroyo Grande, CA
Reg: 01-19-06
09-08-17 06:34 PM - Post#2707110
    In response to Dean50
Here's a picture of my 1950 dash with the original paint.
Attachment: Steering_Wheel_and_shifter..jpg (779.34 KB) 6 View(s)
RAM_51
RAM_51
Reg: 12-28-02
09-08-17 06:55 PM - Post#2707111
Many roads lead to Rome.
1951 Fleetline
Larry E
Loc: Los Angeles
Reg: 09-15-16
09-11-17 12:12 PM - Post#2707398
Hey guys, all of this info has been very helpful. Much appreciated.
Larry E
Loc: Los Angeles
Reg: 09-15-16
09-11-17 12:18 PM - Post#2707400
One of these when I figure out how to upload pics I'll post some.
09-11-17 07:49 PM - Post#2707442
Posting pictures.
Also if you become a supporting member you can post direct from your computer.
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
09-13-17 12:01 AM - Post#2707538
    In response to Mike JW
Mike JW
Your radio looks different from the other stock ones I've seen. Round push buttons versus the square.
Dean50
RAM_51
RAM_51
Reg: 12-28-02
09-13-17 01:17 AM - Post#2707539
Don't mean to answer for Mike, but If I'm not mistaken that is a Motorola, as opposed to the more common factory authorized Delco.
1951 Fleetline
Mike JW
Mike JW
Reg: 01-19-06
09-13-17 06:08 AM - Post#2707552
Ram's right it is a Motorola I think they were sold a Western Auto. When I got my car it had no radio I found that one on e-bay. Its only the radio head not hooked up.
RAM_51
RAM_51
Reg: 12-28-02
09-13-17 03:47 PM - Post#2707595
Motorola also made a manual tune version without the round pushbuttons. Also scanned instructions for the Motorola Radio.
Attachment: IMG_1130.jpg (2.7 MB) 6 View(s)
Attachment: 1949-50_Chevrolet_Motorola_Instructions.jpeg (2.25 MB) 7 View(s)
1951 Fleetline
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
09-14-17 02:54 AM - Post#2707624
Pretty cool. Thanks MikeJW and Ram_51.
Motorola was another one of Bill Lear's ideas, along with Lear Jets and 8 track tapes, etc.
Dean50
Execution time: 0.27 seconds.   Total Queries: 21   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:28 PM
