Username Post: Steering Hub Measurement        (Topic#347008)
1963er
1963er
Loc: Joppa, Md.
Reg: 12-20-15
09-06-17 07:00 AM - Post#2706811
I need the diameter measurement in inches of the 63/64 steering column at the hub where the steering wheel attaches.
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
09-06-17 11:51 AM - Post#2706834
    In response to 1963er
64 columns are a different diameter than 63 steering columms at the steering wheel mounting location.
A 63 steering wheel will not fit a 64 column and a 64 will not fit a 63 column. They will fit but the round surfaces won't line up.
I just took my 64 steering wheels to a friend so I can't compare them to the 63 steering wheels that I have to determine which one is larger.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
62 Imp CV SS 327/300HP 700R4
62 ImpHT SS 409/482 stroker 4 spd
62 Imp SS 409 - 5 spd Convertible under frameoff
Website http://paulstensland.com/
[image]http://chevytalk.org/sm/26453.jpg[/ima
Verne_Frantz
61-64 Subject Matter Expert
Verne_Frantz
Loc: Hightstown,NJ USA
Reg: 08-22-00
09-06-17 06:01 PM - Post#2706872
    In response to pvs409
The '63 is a little larger, but not by much.
Verne
1963er
1963er
Loc: Joppa, Md.
Reg: 12-20-15
09-07-17 03:45 AM - Post#2706894
    In response to Verne_Frantz
Thanks for the advice...but I still need the measurements on both the 63 & 64.....please
Andy4639
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
09-07-17 10:22 AM - Post#2706935
Yes a 63 will fit a 64 column with no problems. As in my tilt column post I have a 63 column with 64 wheel. Yes the 63 is a slight bigger diameter but it's not that noticeable looking straight on. From the side it is though.
I posted a bunch of measurements in the post but not that one. Sorry.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
1963er
1963er
Loc: Joppa, Md.
Reg: 12-20-15
09-08-17 04:12 AM - Post#2706993
    In response to Andy4639
Let me explain why I need this measurement.
I'm looking into buying either a 2 spoke wood steering wheel or the 3 spoke comfort grip wheel.
There are 2 hubs available for this install.
One is 3 7/8" & the other is 4 1/8" and I need to know which one to get for my 63 column.
According to what I have read, the 2 spoke wheel came out in 64.
I don't want to remove my current stock wheel until I find out more about this.
I don't want to do the conversion with that "Hub" not aligning correctly with the top of the column. That's why I need that measurement.
Anymore thoughts or that measurement??
Thanks so far for the info...
55Brodie
55Brodie
Loc: Little River, SC
Reg: 12-26-15
09-08-17 09:30 AM - Post#2707031
Circumference รท 3.1416 = Diameter
09-08-17 04:03 PM - Post#2707080
In other words, a tape measure is your best friend.
Andy4639
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
09-09-17 11:33 AM - Post#2707178
Does this look like your 64 2 spoke wood wheel?
Attachment: 20229231_10203716945682204_8820390468499408142_n.jpg (79.81 KB) 5 View(s)
Attachment: Finished.jpg (69.9 KB) 5 View(s)
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
1963er
1963er
Loc: Joppa, Md.
Reg: 12-20-15
09-10-17 03:45 AM - Post#2707240
That is the right wheel I want to get. It also looks like the hub on yours might be the 4" on it as it is overhanging on the column. Is yours a 64 or 63 column??
Andy4639
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
09-10-17 07:48 AM - Post#2707266
Info from David Hess builder of the Rotten Apple Impala:
1962 Impala's had no tilt wheel from factory.
63-64 Impala are the same columns so any wheel from 63 up should fit as I showed in my post about the tilt wheel being painted.
64 console automatic didn't have tilt either but David found a guy in Cal. that takes your column and makes it a tilt weather it is are not doesn't matter.
I installed several wheels even a 67 truck wheel that fit the shaft. The wood wheel worked but I couldn't get the horn to blow right. Some times it would and others it would start blowing on it's own. It works perfect with the blue and white wheel. The horn spring is different in the wood wheel.
Attachment: 20292834_10203716937802007_4243617238605171717_n.jpg (70.59 KB) 4 View(s)
This is the wheel that came with it.
Attachment: rotten_apple1.jpg (133.63 KB) 4 View(s)
The start!
Attachment: rotten_apple2.jpg (206.33 KB) 4 View(s)
Finished product
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Edited by Andy4639 on 09-10-17 07:52 AM. Reason for edit: No reason given.
Andy4639
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
09-10-17 10:29 AM - Post#2707285
Took some pictures of the column. It's a 63 column according to the numbers.
Attachment: 21433011_10203898907831144_291489596036365762_n.jpg (56.34 KB) 4 View(s)
Attachment: 21462548_10203898908031149_8642210219552983773_n.jpg (63.31 KB) 3 View(s)
Numbers on the bottom of column
Attachment: 21616498_10203898907751142_1144753686730096560_n.jpg (50.4 KB) 4 View(s)
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Verne_Frantz
Verne_Frantz
Reg: 08-22-00
09-10-17 11:13 AM - Post#2707289
A couple corrections:
'64s with an auto shift on the floor were able to have a tilt wheel. All floor shift tilts are the same, whether the car was an auto or a 4-spd.
The column you showed is actually a '64. It's dated the 357th day of '63 which is in the '64 model year.
Verne
Notice how well the '64 wheel fits on it.
Edited by Verne_Frantz on 09-10-17 11:27 AM. Reason for edit: No reason given.
Andy4639
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
09-10-17 12:03 PM - Post#2707290
Verne
I was wondering if that was the day of it being built.
I was misinformed on the auto console tilt then. No big deal but at least I want tell anyone the wrong info.
The non tilt turn signal cam want fit the tilt column either just for info.
Attachment: 20292638_10203716927761756_4342796718993268697_n.jpg (74.33 KB) 4 View(s)
67 C-10 truck wheel fits the hub shaft.
Attachment: 20246225_10203717496935985_162382451824546499_n.jpg (53.51 KB) 3 View(s)
A non tilt turn signal cam want fit a tilt wheel.
Attachment: 20245774_10203717496055963_4100973573856675392_n.jpg (69.02 KB) 4 View(s)
Both signal cams.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Edited by Andy4639 on 09-10-17 12:08 PM. Reason for edit: No reason given.
Execution time: 0.262 seconds.   Total Queries: 20   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:25 PM
